Audio in a 2007 TL-help needed
Old Mar 31, 2011 | 09:51 AM
ROWDY621's Avatar
Just was wondering if any of you guys can reccomend a good car audio shop around the Kansas City Missouri area? Was looking to replace all spekers with Alpine type R's and put a sub and amps in. By the way, what size speakers are in the rear of a 2007 acura tl? I know they are 6.5's up front, but I have heard they are both 6.5's or 6X9's Someone help clear this up. Finally any of you guys replace you whole sound system how much did if run you guys if you don't mind me asking?
Thanks Guys
Old Mar 31, 2011 | 10:02 AM
invalidalias's Avatar
system
shoot unless the speakers are blown I would just put 2 12s in the trunk.
Old Mar 31, 2011 | 10:06 AM
ROWDY621's Avatar
yeah I thought about that as well, but would say like an Alpine type R speaker be a little better than whats in there now? I would think so, also can are stock speakers be hooked up to a 4-channel amp or would that be too much power going to the stock speakers?
Old Mar 31, 2011 | 10:15 AM
adsoldschool's Avatar
I'd rather be golfing
from my recent experience with my 06 TL (I kept the factory head unit, replaced all speakers, added subs and amps and a Rockford 3Sixty processor) and if you decide to keep the factory head unit, MAKE SURE they have experience with head units that have ultra-low voltage output!!! The factory unit in mine (yours is probably the same?) has such a low turn-on output that it does not turn the 3Sixty on and the car does not have a remote turn-on wire like old-school head units. My system is "hot" as soon as the key is turned, even if the radio is off. You'll see a lot of posts on here about trying to tie into a fuse or input line that allows for the aftermarket stuff to not be "hot" all the time. Good luck!
Old Mar 31, 2011 | 10:43 AM
Trunk Monkey's Avatar
Coolest A-zine Member
Rowdy- What's your budget for all this?
Old Mar 31, 2011 | 11:01 AM
jda123's Avatar
Dogmatic Dinosaur
I am in KC if you ever want some help.
I would keep the stocks rather than upgrade to Type R speakers - they juice would not be worth the squeeze to me.
Speaker sizes:
3.5" center - single speaker
6.5 components up front - 6.5 midbass and about a 1" tweeter
6.5 rear - single speaker
8" sub
Old Mar 31, 2011 | 11:28 AM
ROWDY621's Avatar
Well I already have all the amp wiring as well as the sub, and two amps so I would just be looking at speakers if I decide to go that route and install, but I was wanting a custome sub enclosure. The one that fists into the corner of the trunk. Looks sweet and like it belongs there anyone have any pics of that?
Old Mar 31, 2011 | 11:32 AM
jda123's Avatar
Dogmatic Dinosaur
I have one in each of my TLs. They are about $350 or so online new. They usually take 12" subs, but I have seen one for a 10. A shop can make you a custom one, or you can buy them online.
Here is a pic of the one in my 2006. The 2004 looks the same except the dust cover logo is red instead of white. Forgive the mess in my wife's car - we use the trunks.
What kind of sub and amp do you have?
Old Mar 31, 2011 | 12:09 PM
ROWDY621's Avatar
All Alpine stuff. Have a 10" Alpine Type R wanting to put that into that enclosure. Along a V-12 Powered Alpine Amp. Did you make that or did you buy it? Does it rattle the crap out of the trunk or is it not that bad?
Old Mar 31, 2011 | 01:14 PM
jda123's Avatar
Dogmatic Dinosaur
I bought both of mine. I put 4 screws into the license plate, took out the trunk counterweight and fixed the standard deck rattles and it does not rattle the crap out of the trunk even beyond normal listening levels. I put deadener in the 2004 and I probably would not deaden the trunk again - did not gain that much.
IMO the Image Dynamics CTX65CS are about the same price (maybe a bit more) as Type R comps and they are significantly better - for your consideration.
Which V12s do you have? 75-100W to the fronts and 300-500 for a sub would be a nice start in a TL.
Old Mar 31, 2011 | 01:20 PM
eggyhustles's Avatar
Alpine type r sealed= upper fail
Old Mar 31, 2011 | 01:50 PM
ROWDY621's Avatar
I don't get it what's wrong with Alpine? I had all of this in m RSX and it sounded pretty decent. I just figured should use what I have rather then buy new stuff.
Old Mar 31, 2011 | 01:55 PM
ROWDY621's Avatar
yeah that is what I think it is 75w to the front and 500 to the sub. So what are brand name of the factory speakers?
Old Mar 31, 2011 | 01:56 PM
Type r is an spl oriented woofer. It belongs in ported only.
Old Mar 31, 2011 | 02:27 PM
jda123's Avatar
Dogmatic Dinosaur
I have never used a Type R - I have no firsthand experience.
You can use them sealed - won't hurt them physically... the newer ones, at least. If you were happy with yours sealed, then go for it. Did you use is sealed or ported in your RSX? SPL subs are usually very peaky sounding in sealed enclosures.
The factory speakers are supposedly Bose.
Old Apr 1, 2011 | 11:23 AM
ROWDY621's Avatar
jda123, where did you purchase for enclsoure for you TL? how much did you pay if you don't mind me asking? I just checked with a shop and they want a pretty penny to build one. Also, if any of you have an ipod adapter which one? I have hear i-simple is good but also there is The USA-Spec one as well which one is better? what are the differences?
Thanks,
Old Apr 1, 2011 | 11:36 AM
jda123's Avatar
Dogmatic Dinosaur
I got mine from Audio Integrations:
http://www.audiointegrations.net/cat...75/8253904.htm
There is a member on here that makes them. You can search for "uncald4".
There is a 10" one on ebay:
http://cgi.ebay.com/ebaymotors/Custo...fAudioQ5fVideo
You could use a 12" enclosure putting a 12" to 10" ring on the front.
I have a iSimple. Both units are about the same. Both use the factory controls and take a while to get used to. Neither are intuitive. There are tons of threads on them. Be cautious of reviews of either from new users - many people are not happy when they first get them becuase they take a while to learn. They are not like using an iPod or some Apple device that you can master in 2 minutes.
Old Apr 1, 2011 | 12:08 PM
ROWDY621's Avatar
Do you think my 10" alpine Type R will fit in this enclosure? would it still sound good? I had it in a ported box in my RSX what would be the diff in enclosures. This would be powered by a Alpine V12-500w amp. where did you mount your amp at?
Old Apr 1, 2011 | 12:45 PM
jda123's Avatar
Dogmatic Dinosaur
I have no idea about the sound.
I fabricated metal brackets and I mounted my amps through the factory side molding to the metal. It is not as slick as a lot of setup, but I am a function over form kind of guy. I wanted to keep the rear seat and rear deck as open as possible to let as much sound into the car as possible.
Old Apr 1, 2011 | 03:28 PM
ROWDY621's Avatar
jda, real quick I am on the site you bought your enclosure on? Is this compatiable with a trunk tray?
Old Apr 1, 2011 | 03:51 PM
jda123's Avatar
Dogmatic Dinosaur
I have it over the trunk tray in my 2006. In the 2004, I cut the trunk tray to fit behind/under it about an inch or so for the looks - it looks like the trunk tray is underneath it.
Old Apr 3, 2011 | 02:56 PM
ROWDY621's Avatar
Does any one know where I could get a corner sub enclosure for my TL that matches the carpet exactly? I looked on that wickedcas.com site and it looks that pic didnt match the carpet in that TL. I have a ASM TL with taupe interior the trunk is grayish in color???
Old Apr 6, 2011 | 12:19 PM
ROWDY621's Avatar
I found my contact for the custom enclosure uncald4 will make mine has anyone else had uncald4 make an enclosure for them? If so can some of you guys post pics of how it looks in you trunk so I can get a good idea of how it will look? thanks
Old Apr 6, 2011 | 12:28 PM
He makes good boxes.
Just don't put a type r in it
Old Apr 6, 2011 | 12:30 PM
ROWDY621's Avatar
EGGY, what is with the non-typr r in that box? Here is what he said about it being in that box: A sealed box has a very broad frequency response and it's performance is very equal across it's range. Because of this it can reproduce lower bass notes and way more boom than a ported box. A sealed box is best for rap and R&B music because the bass notes are more emphasized in the lower frequency range. I am fine with this????
Old Apr 6, 2011 | 12:46 PM
False.
Spl subs don't belong in sealed boxes. There's gonna be a lot of peaks and valleys in the frequency response.
Now, the type r slim works in small sealed.
Old Apr 6, 2011 | 12:50 PM
myron's Avatar
he is saying that that particular sub is better put into a ported box, not sealed. Doesn't matter who makes the box
Old Apr 6, 2011 | 01:04 PM
Sealed Box = SQ
Ported (35-45hz) = SPL
Ported (25-32hz) = SQ low end extension
Subs are made for a specific purpose and when you put in SPL-oriented sub into an sealed (SQ) enclosure, you will not yield the full potential, and vise versa with a different sub. Ported box will give you better low end and less cone movement in the frequency range, BUT will give you a time-delay type thing. Here's a good read:
http://diyaudiocorner.tripod.com/dilemma.htm
Old Apr 7, 2011 | 12:40 PM
uncald5's Avatar
newb
Good words ROWDY. We've done the TYPE-R sub in several different boxes in the TL trunk. It does have a much higher output in a ported box but you lose the lower and upper frequency band. The sealed box will not allow for that loss and is pretty consistent across the range.
Old Apr 8, 2011 | 06:11 PM
xxx_busa's Avatar
go to DIYMA your answers will be considerable better than whats being feed to you here. PLUS your tread has been Jacked
Thanks Guys
Old Apr 8, 2011 | 09:47 PM
RBeachTL's Avatar
I highly recommend Travis; you should also listen to his advice on cost effective upgrade solutions.
Old Apr 11, 2011 | 10:33 PM
uncald5's Avatar
newb
Damn! That is a beautiful setup! Thank you for your kind words also.
Old Apr 12, 2011 | 12:09 AM
Steven Bell's Avatar
Thanks Guys
Rowdy, in the Kansas City area, try Santa Fe Auto Sound in Overland Park, KS.
2011 National AcuraZine Meet-Kansas City-June 12, 2011-Details Here!
Old Apr 12, 2011 | 10:49 AM
ROWDY621's Avatar
Hey guys was wondering, not the best at this audio stuff. Do you guys feel that a custom car audio shop or a Best Buy should do an install with sub's and amps and components? I have heard both places are decents depending on what installer you get, but just wanted to know who would have more knowledge (and less likely to mess something up) Also, what would the price diff be for labor? Should one be cheaper than the other?
Old Apr 12, 2011 | 01:32 PM
You'll just have to call and get a quote for each specific place. If you having to get multiple things installed then they might cut you a deal at the smaller shops, not at a big box store like Best Buy.
Old Apr 12, 2011 | 02:06 PM
ROWDY621's Avatar
What do you guys think an install of a 4-channel amp, 4 speakers, sub/amp combo, and and ipod adapter would run? Just ballpark in a 2007 TL
notfast
1/2G MDX (2001-2013)
Mar 28, 2023 08:10 AM
Feb 25, 2020 09:57 AM
wilztlxs
Dec 1, 2015 09:16 AM
sockr1
Oct 1, 2015 01:31 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
