Anyway to clear error codes stored in Nav?
Try this and if there is a problem the message will come back, otherwise this worked for me and will you as well.
You'll need to evoke the diagnostic screen first, get in your car, turn the nav on, and hold down the "GUIDE", "MENU", and "CANCEL" buttons for about 5 seconds. The factory calibration screen will come up.
Then click on XM module, and you'll see the option to erase those messages. Believe it or not the diagnostic messages are stored in XM module.. dumb.
P.S. word of advice, be careful
Stay Out Of the Left Lane
Sorry for the delayed reply. If the prior owner "had the navi conversion done," it's possible it wasn't done correctly, but it may have been done okay. If everything is red, I would make sure the care is running or at least the ignition is on. Some of the components of the diagnostics stay red because they need to the ignition on or engine running. It's been a while since I have had a code to clear, so I I can't give you any further specifics related to the XM Hip. What I posted above worked for me in the past.
mada51589
Jan 9, 2025 04:40 PM
