any suggestions on a good sub and amp?
Federation Squirtle Squad
...im looking to get a decent sub and amp for an 06 TL, anybody got any good suggestions?
...i dont need anything too fancy, just looking to spend around $300
Well, I have an Infinity 700 watt mono amp I would sell you for 175, and you could get this sub from woofersetc for 149. That puts you pretty darn close. Heard nothing but good things about the sub, and it sounded quite nice at local dealer...
http://www.woofersetc.com/index.cfm?...roduct_ID=3147
First of all, you have to ask yourself some ?'s. Like, what size woofer do I want? How big will the box be? Will you get a custom box or prefab box? What kind of bass are you looking for? SPL or SQ. Good thing is we already know your budget.
IMO, I don't know about that sub. On that page it says
"Rec. Sealed Box Dims: not recommended
Rec. Ported Box Dims: not recommended
Free Air Usage: not recommended"
So what the hell does that leave you with. Bandpass?!?! Maybe the specs on that page arent correct but I've never been a huge fan of JBL. If you wanna get a good sub look around online. Ebay is great. www.onlinecarstereo.com has great prices. And www.woofersetc.com is a great site too. Then once you find what you're looking for, froogle it or go to bizrate.com and find the best price. That's how I found all my equipment. Good luck w/ whatever you end up getting!! And SHARE PICS!!
...not sure what size yet, perhaps something rectangular, almost like the size of an xbox or so, i just wanted something that looks nice and sounds well
i've been looking thru eBay because thats where i buy almost everything on, so far im thinking of Infinity or JL, not quite sure at this point, perhaps an Infinity amp and a JL sub
Darkcyde-
Perhaps you should do a bit of research before rushing to judgment-Like on JBLs website. Woofersetc simply has not downloaded the enclosure information into their website for that particular woofer, as is the case with many other woofers.
That particular woofer would work well in small sealed enclosures. All of the Thiele-Small parameters are readily available on JBLs website. I was very impressed listening to this sub- it didnt take a ton of power to get it to move like most of the new uberwoofers, and had an exceptionally natural sound to it.
I, like you Darkcyde have a 12 inch Kappa Perfect DVQ (mine is in a sealed enclosure) that I am very happy with....as a matter of fact I am in the process of adding another. Wonderful sound quality, it plays low, and gets plenty loud. (I am also in the process of adding a Boston Acoustics Pro 6.0 soundstage up front with 250 watts per side, so I am adding another 12, mostly for fun
You can find the Infinity Kappa Perfect DVQs on ebay for around 150 or less also, it would be a fine choice as well. It seems as if the Kappa perfect and the new JBL power subs have a pretty similar frame, which would make sense since there parent company is Harman.
You are correct Darkcyde- listening to a sub in a sound room is not the same as in a vehicle, but when there are JL w6, Memphis, Type Xs, and a couple other fine subs in the same room, you can get a reasonable sense of the musicality, quality and performance of each individual woofer.
As you can see AzNGR81, there are many good subs available in that price range...
the list is probably over 2 dozen woofers long, It all comes down to what you have the opportunity to hear and like, and brand preference...
Diamond D6
MB Quart Premium
Dayton Reference high fidelity
JBL Power
Infinity Kappa perfect
JL w3
Soundsplinter
RE Audio
Boston acoustics g5
Elemental Designs 13V0 (never heard one of these personally, but many folks swear by them)
Diamond D6
MB Quart Premium
JBL Power
JL w3
Soundsplinter
RE Audio
Boston acoustics g5
and btw azngr81, many members are using Infinity components and I haven't read any bad things yet. are you going for a big boom (SPL) or sound quality (SQ) setup? this makes a difference as to what woofer/amp/box you should get.
Diamond D6
MB Quart Premium
JBL Power
JL w3
Soundsplinter
RE Audio
Boston acoustics g5
Diamond D6
MB Quart Premium
JBL Power
JL w3
Soundsplinter
RE Audio
Boston acoustics g5
Originally Posted by AzNGR81
...yeah my friend told me to get the Infinity Kappa Perfect, so im most likely going to get that, now im just looking around for some JL subs, well do you know if i need any additional accessories or items for installation?
Infinity also makes a line of amplifiers, but they are referred to as the "reference" series.
Feel free to PM me if you would like....or here is an itemized list of what you would likely need
1 Mono amplifier of your choice that puts out roughly 450-750 watts RMS
2 Line output converter
3 a subwoofer (the Kappa perfect, or the Jl sub, but not both)
4 A proper enclosure for that subwoofer, based on manufacturer parameters
5 an amplifier installation kit that has at least 8 guage power wire, and is fused at the battery.
...whoops didnt realize the infinity kappa perfects were subs not amps, now i just need an amp
If you are interested in the infinity amp I have, just PM me they do work really well together!
I decided on a JL-HO10W6 which is a 10" sub in a rear firing tuned encloser matched with a JL 250-1 mono block amp. I feel the thump in the center of my back whenever I pop in a good DVD-A disk, I have the input sensitivity turned right down on the JL amp so it was'nt so overpowering.
Still lots of room in my trunk and I can access my spare no problem.
Looks like you type quicker than I do
I went with a 1.0 cu ft sealed enclosure with the mid q insert. It sounds great, and plays quite low. I would like to add a bit of polyfill to it as well. I had two JL 10W0 before in a sealed enclosure, and the Kappa perfect 12 just slays them! (as one might expect, the jl w10 are a good entry level sub, but thats about it!)
Trucki!!
lembowski,
Sub looks good! I will probably be going with this unit as well!
I noticed that you have 4 RCA connectors going in to the amp. Did you get the low level input from the connection prior to the factory amp in the kick panel? Why are there 4 connectors instead of just 1?
Any reason you got the Basslink instead of the Basslink II? Now that I have seen your install, I will probably go with the Basslink as it looks like if fits perfectly in the spot you mounted it. The Basslink II is a little bigger I think.
Trucki!!
Originally Posted by Kikaida
lembowski,
I purchased the regular basslink because I got it locally off of craigslist for $70........couldn't beat that. Especially since the II is like $400.
All together I sent $110 for basslink, wires and level input
Originally Posted by lembowski
Thats what is coming off the level input I got. I ran it off the rear deck......not from the front. That would just be too much work running the wire.
You got a Line-Level Converter? Doesn't the Basslink have one built in? I think Infinity refers to it as the "Universal Interface". Looks like molex type connectors are required to plug into that though. I am guessing the unit you bought didn't come with those wires.
I have seen the Basslink locally at Best Buy, but it's $299 there. I will probably pick one up on eBay... Problem is alot of people won't ship to Hawaii...
Originally Posted by cacicgt7
what's the basslink II?
Originally Posted by mrshowbiz122
Think buying 2 basslinks and putting 1 on each side of the trunk is a good idea?
I am only planning on supplimenting the stock system with a little more bass. I personally think that just the one Basslink would be sufficient for my own needs.
AndrewS
19
03-14-2024 06:59 PM
mada51589
05-03-2022 08:54 PM
saberlove
03-11-2021 09:29 AM
