Any suggestions on '08 ELS 5.1 sound system upgrades?
#241
#242
Day 2 and 90% done. All pannels back on and wiring done. Just wiring up the amp and BLD and I'll be seeing how these focal sound in the TL!
I'll post up some pictures when I get home as well of the eye candy.
#243
Everything done and in... couple questions
1. Have a slight hiss with volume all the way down.
2. Im running at highpass on the amp, is that what most (jda) run in your same type set-up.
3. I have all the gains turned down and the amp still seems to be overpowering.
Overall it does sound 1000x better but still have a few issues
#245
Anyone that can help i'd appreciate it. I pretty much ran a set-up that eggy, trunk monkey, jda, all said would push the focals well. Well not it seems that the T-400-2 (which i was told to get for "headroom") is powering my components to the max with all gains down.
#248
#249
Re-grounded the amp, hardwired rca's to the pre-amp and still having hiss issue. Has anyone had problems with the RF t-400-2 causing noise even with a RF-BLD? Im at a loss for words, me and my installer have put over 10 hours into this thing with no luck of getting it perfect. He believes its the amp?
#252
New ground picture below, would changing ground location help? My installer put dif. volt meters and still couldn't come up with a reason why im getting the static sound.
#253
Have you turned the line driver all the way down? Are you sure the signal is taken pre-amp?
#254
#255
It really sounds like high level inputs going into the line driver. You would have way too much volume even with the gains turned down and noise would be horrific.
FWIW, I always had some level of hiss after the stock amp but ignition noise was low to non existent. It sounds a lot like yours. It also looks like you have your power wire close to the RCAs. Probably not your issue especially with it after the line driver but just temporarily moving it wouldn't hurt.
#256
There's a black and a grey connector at the stock amp. One goes to the speakers (post amp) and one goes from the HU to the amp. I can't remember which one is which but I just saw it in one of the active threads in here.
Volume at like 18 is LOUD and I can tell im not getting the sound i should, after like 27-29 certain songs start to distort and clip.
#257
If you turn the gains all the way down, what happens? Does the amp have a hi/low switch?
#258
Where do you currently have the gains set on both the line driver and amp? It's not completely abnormal for it to distort around 30. I usually set my gains so that I can play up to at least 35 with no distortion.
I've messed with the setting on the amp. If i turn ANY of the gains anything past zero they static just increases.
#259
Is the static mostly through the tweeters? Sounds suspiciously like the ground loop issue I can before my 3sixty.2. The BLD needs to be set balanced in, and unbalanced out for sure.
#260
Oh, and your inputs on the BLD are wired to the high level ins. Either your installer didnt grab the preamp signal, or its wired incorrectly. I bet he thought the BLD was a LOC, not a line driver. Its much more common arrangement.
#261
How should I explain to him to re-wire the bld? or is it something i can do myself? Im a noob when it comes to wiring diagrams and things like that, but very anxious to get this sounding right.
#263
In this pic, the BLD appears to be wired correctly. The RCA's in are wired to a blk/gray pair and a green/blue pair. Black and green are the positive wires and should be the center pin on the rca. The gain should be set with a test CD so that the 2.5v light is lit, not the 5v light. (1khz 0db tone) Remote switch set to in. Other side of the unit, set the output to unbalanced. (It looks like this may be set wrong, but its hard to tell from the angle)
Oddly enough this unit and the manual are different than the reference pic on the product page I was looking at before.
#264
That sounds exactly like what me and trunk monkey were dealing with. I bet once you get the switches set right, it'll go away.
#265
I've changed all the settings multiple times and it's still.static. does the wiring in the recent pictures. Look correct? When I get home ill mess with the settings again but.I feel as thou it's either wiring or some sort of ground loop somewhere ... It's driving me nuts.
#266
#267
Well I may have came up with new developments that i'm sure will narrow down the issue. I was sitting in my car today with the volume all the way down, i turned my headlights on and i heard another weird noise come thru the tweets.....hmmmm... So i run to the store and back home and I turn my car off but to the point where my aux, radio etc is still on. 90% of the static was gone while my engine was off BUT radio was still on. So with half a key turned the static is mostly gone but once the car starts the static is all there.
#268
It's still a line level issue. For whatever reason, there's waaaay too much gain. Does your amp have a hi/low setting?
#269
Yeah it has low pass, high pass, and AP.
#270
#272
Here's the way I look at it. If you only had a noise issue I would say possible ground loop issue. However, it's way too loud with the gains all the way down AND you have noise issues. It's not a ground loop issue, it's a level issue. Find out why you're getting too much voltage. Measure voltage going into the amp and work your way back. You'll find the problem.
#273
I'll have to go out and look. . . If i post more pictures at least of where he tapped in and settings would that help narrow down the problem? When i seen my installer Monday i'd like to have it narrowed down as possible.
#275
Wouldn't it be narrowed to a ground due to when the motor starts I hear every noise in the car through the tweets lol. Or could that be a line level issue as well?
#277
Until you get it figured out- One of these will tame the noise issue.
http://www.amazon.com/Raptor-GL15-Gr.../dp/B0009O19LQ
I wouldn't leave it in on a permanent basis, but at least you won't go mad while figuring it out.
#278
#279
I still think the crux of the issue is getting the BLD setup right.
