Angrydad/MID Trip Computer Conflict
practicing nihilist
I searched but didn't find anything on this issue:
I noticed just after installing the Angyrdad Navi Hacks that the trip computer mod didn't jive with the MID for Range and MPG.
Example - right now the AD mod says I have I'm getting 24.6 mpg and have 286 miles remaining. MID says 24 mpg and 277 miles remaining.
If they were getting the info from the same place the MID should be reading 25 mpg. I've seen over 1 mpg mis-compare between the two.
Input?
Input?
OMGWTF4THGENTL
It's a known issue... or non-issue to be correct.
It seems the mid calculation is derived from a different calculation than the nav programming.
Someone in an OLD thread showed how thier Accord, which has this capability from the factory, showed a minor discrepancy as you described between the 2 numbers, so it appears to be working "as designed" if you will.
It's also been reported that those two numbers "converge" the lower the gas gauge gets...
practicing nihilist
Thanks, Kennedy.
Did anyone ever derive which you should trust? My wife is the kind that freaks out when the range hits 0. I know better but it would help if someone had insight on which is more accurate.
practicing nihilist
Originally Posted by Tripnbeats
when u hit 0 u still have about 60 miles left to go or 3 gallons of gas.
OMGWTF4THGENTL
Originally Posted by NedShneebly
Yep, I'm aware of that. If there's a 10 mile difference between the two and you were really strapped for a pit stop, it'd be helpful to know which to trust. Oh, and I'm really praying the AD is more accurate because it shows better mileage...guess I could just calculate the old fashioned way for a test.
AcuraKidd
09-25-2015 11:18 PM
