Amplifier question
Old Feb 3, 2014 | 01:55 PM
GrantD's Avatar
Amplifier question
Hey I am concerned with what amp I should get or what wattage is needed for this subwoofer
Amazon.com: Kicker CompVR 07CVR122 12-Inch 2-Ohm DVC Subwoofer: Car Electronics Amazon.com: Kicker CompVR 07CVR122 12-Inch 2-Ohm DVC Subwoofer: Car Electronics
I was looking at the 500 watt amp by JL
Amazon.com: Jl Audio Jx500/1d Mono Subwoofer Amplifier - 500 Watts RMS X 1 At 2 Ohms: Car Electronics Amazon.com: Jl Audio Jx500/1d Mono Subwoofer Amplifier - 500 Watts RMS X 1 At 2 Ohms: Car Electronics
Give me some ideas please.
Thanks.
Old Apr 8, 2014 | 01:01 PM
the_tl_man09's Avatar
Can't go wrong with a hifonics brutus. I got a 2100 watt brutus for my two kicker cvx's and when i tell you im slamming i mean im slamming. broke my windshield smh
Old Apr 8, 2014 | 03:48 PM
DiamondJoeQuimby's Avatar
Codename Duchess
That is a DVC 2 ohm sub so either 4 ohm or 1 ohm load. That amp does 500 watts at 2 ohm, isn't stable at 1, and is 300 at 4 ohm.
The amp is a little under what the sub is rated at, but will be fine as long as you run it at 4 ohm.
Old Apr 8, 2014 | 03:52 PM
Vlad_Type_S's Avatar
Registered Bike Offender
Do you already have the sub? If you're running just one of these, I highly recommend getting the 4 Ohm DVC version as you will spend less on a 400W @ 2Ohms amp than 400W @ 4 ohms. If you had the 4 Ohm version of the CVR, the JL amp that you selected would be perfect.
For that sub (great bang/buck, by the way. I had 2 15" of these once), you'll either want something that is capable of 400W @ 4 Ohms, or 400W @ 1 Ohm. The 15" version has 500/1000 W power handling, and I was running them at 2000W for like 3 years with no issue on a class AB amp. The amp overheated from time to time though lol.
That JL amp will work but you can go higher with the power as it only gives 300W @ 4 ohms. Here are a few other contenders:
http://www.crutchfield.com/p_108R160...0a.html?tp=115
http://www.crutchfield.com/p_500MRXM...55.html?tp=115
http://www.crutchfield.com/p_109GTO7...EZ.html?tp=115
http://www.crutchfield.com/p_113XR60...-1.html?tp=115
http://www.crutchfield.com/p_113KAC9...6D.html?tp=115
Lol Mayor Quimby beat me to it.
4drviper
Apr 23, 2025 07:13 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
