Amplifier Mute question
Old Apr 28, 2005 | 04:29 PM
bklynpanman's Avatar
321 whp SAE
Question for anybody who has replaced the stock amp with a new one.. Did you lose the nav mute and the HFL mute? there is an amplifier mute wire going into the stock amp, this is why i ask. thanks
Old Apr 6, 2008 | 06:27 PM
ors's Avatar
ors
Great question, I have been searching and I also could not find an answer? I plan to use the 3Sixty and not sure whats the best place to conect, Before or after the amp
Old Apr 6, 2008 | 09:32 PM
JohnnyB1976's Avatar
I very highly recommend going before the amp and bypassing it completely. I used a 4 channel JL Audio in the trunk for the front and rears, the line level from the HU was perfect for it, very clean.
I plan on recycling the old factory amp as a center channel amp. I did not lose any functionality whatsoever not having the mute line hooked up. As of right now, when using NAV, I don't have the voice prompts without that 5th channel running. With a speaker hooked up directly to the line-level center channel, I can hear the voice, faintly, so I'm sure that it'll work fine once I get the other amp in there.
Rip that thing out! You'll be happy!
Old Apr 7, 2008 | 06:07 PM
ors's Avatar
ors
I will give it a try, I was concern that I would not hear the nag voice prompts.
At the stock amp location is where I want to install the 3sixty.2.
4drviper
Apr 23, 2025 07:13 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
