Amplifier connection
Old Sep 28, 2008 | 04:18 PM
Falen's Avatar
I want to change my front and rear speakers with a 4 channel amplifier, Do the Acura TL have rca plug left and right behind the stock radio to connect an amplifier??????? if not how do I connect an amplifier????
Old Sep 28, 2008 | 05:15 PM
csmeance's Avatar
nope, just 40 pin wire harnneses. What you will need to do is tap after the stock amplifier since the signal is to weak after the head unit. The stock amplifer is lockated under the glovebox in the panel where your right foot would hit. You will need to connect the wires to some patch RCA cable.
Old Oct 4, 2008 | 06:04 PM
Falen's Avatar
any infos
Old Oct 4, 2008 | 09:32 PM
Trew's Avatar
What would you like to know?
Here's a link to the radio wiring diagram
https://acurazine.com/forums/showthr...wiring+diagram
Here's a link to a stereo upgrade DIY
https://acurazine.com/forums/showthr...hlight=install
Grab a Snickers. You'll be reading for a while. If you research everything, there will be little chance that you will mess something up.
Good luck
Old Oct 5, 2008 | 03:20 AM
Falen's Avatar
i want to repalce my four speakers (2 front and 2 rear) with an amplifier for them.
Old Oct 5, 2008 | 08:34 AM
CSWBiggs's Avatar
Year and options on your 3G?
Old Oct 9, 2008 | 12:37 AM
jetblakTL's Avatar
The Darker the berry....
You need a LOC - line output converter. All the speaker wires go into the LOC and it has RCA outputs. The LOC must go after the stock AMP.
Old Oct 6, 2009 | 08:07 PM
mr2tim's Avatar
Need help w wire id's on 2000 TL 100W Amp assy would like to use it's compact size but am lost without input and output wire references. Thanks in advance, Tim plandcs@aol.com
Old Jun 8, 2014 | 09:16 PM
tsx111's Avatar
3rd Gear
has anybody checked out the pac hon20? I am in the process of swapping speakers in my 08 tsx (no navi) and this seems to be the easiest way to go to add an amp to the rear deck and the front doors. will leave stock amp to the rear doors and keep all controls working as they do now. the harness is plug and play which is a blessing after seeing how tight the wiring is to the factory amp.
Old Mar 24, 2016 | 09:52 AM
riversnj's Avatar
am considering purchasing this harness adapter. will let yall know the outcome
4drviper
Apr 23, 2025 07:13 PM
knight rider
Mar 4, 2016 08:59 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
