Amp/sub installed, no sound - help!
Recently had a JL 10W6 and and JL 500/1 temporarily installed in my 07 TL/nav while I wait for Uncald 4's custom enclosure to arrive. The stock sub was unplugged to power the new amp/sub combo but it only works when the car is on. I have no sub/bass when running on accessory power and it sounds terrible. How do I fix this?
Installer was a friend of my son who had 8 years experience at Tweeter and I thought there would be no problems.
Should I be looking for another installer? Help!!!!!
To make the sub come on with the key in the accessory position, you have to find a trigger point that's hot with the key in accessory. I can't remember off the top of my head where most people grab the power from but I've seen it posted before.
you could just get a multimeter and test open fuse slots in the fuse box and see if any are hot with ACC on and not when the key is off. I havent done it yet with my TL but thats how I wired in my radar in my old truck. On the TL I have my amp remote wired to a wire coming out of the power mirror switch harness- I forget which color it is though. It comes on with ACC and ON
the problem with the 07 type s is that you have to remove the rear ANC(active noise cancellation) plug its in the rear dome light.
1) pop off light covers using jewels screwdriver or butter knife just be a little gentle but not scared.
2) two screws located on either side. unscrew them using a phillips i believe
3) the wire is fastened by a B**** of a zip tie... patience is key.. i was very fustrated by this... but basically you have to unplug this wire or all 07 type s owners who do an AM amp/sub install will experience weird thumping or
Skirmich
09-15-2015 06:41 PM
