Amp Install Help Please
Any help with this issue would be greatly appreciated. I have a mono amp with high inputs connected to a 12'' sub. I ran the power cable and have a good secure ground wire. I connected the stock sub leads to the high inputs on the amp. Every install that I have read on the forum doesn't say to run the 12v remote lead, so I haven't (I am retaining the stock HU). However, when I bolted everything back in place and went to run it, the amp is dead. Please tell me I missed something stupid.
Thanks in advance
Thanks in advance
Ok, I feel kinda dumb. I just looked through some other threads and realized that I do need to run the 12v remote lead. Any ideas on where to run it? I don't have access to a voltmeter to verify the source.
On a side note: Did you guys run this remote wire down the drivers side along with the power cable for the amp. Would this cause interference?
I ran mine with the power cable
I've been taught to keep signal wires and power wires separate, so I ran my remote wire along with the power cable on the driver's side. I didn't want any noise to be transmitted to the signal cables from the remote wire, since the remote wire is connected to the same noise generating power source as the main power cable, the alternator.
AndrewS
19
03-14-2024 06:59 PM
Pegon95
09-15-2015 01:54 PM
