Amp bypass and connection questions
Hey everyone! I'm looking for information that's very specific that I'm having a hard time locating. I bought a DIY amp bypass kit from the guys at Mobile Max Car Audio but it doesn't include the leads for ground and power for DC. I'm installing the Kicker 47Key200.4 and wanted to use DC vs 12v so I don't have to run extra wire. Where can I find the male pins for the connectors. Not the small pins but the bigger one. The best picture for reference is the lead on the actual amplifier, that should be constant and ground in the middle. It's a spade style crimp terminal, I don't know the pitch and everything else. I need a part number more than anything. Acura was unhelpful, most of the people I spoke to just don't know. I am patient so I'm in no rush right now to get it installed. I've considered buying and broken amp and just removing the connectors from the amps mobo but if you all can help me that would be better. Thank you!
I'm using this kit:
https://mobilemaxcaraudio.com/produc...ypass-harness/
I'm using this kit:
You post has a lot of words, but i'm not quite understanding what your ask is. You're looking for a part number for a spade style crimp terminal?
Why not just go on Amazon and buy an assorted pack of crimp terminals and see what fits?
Also this one is the most confusing:
what do you mean by DC vs 12V? Are you somehow implying that our cars use 12V AC and you would be tying it in there?
Why not just go on Amazon and buy an assorted pack of crimp terminals and see what fits?Also this one is the most confusing:
and wanted to use DC vs 12v so I don't have to run extra wire. /
I think i'm understanding now.. I still think your best bet is buy an assorted kit and compare it to the existing pins to determine the right pitch as I don't think you'll find an Acura part number for a specific pin.
Try this site: https://cycleterminal.com/
Male end pinout
Female End Constant and Ground
@MasterWayne
Are you planning to use the 12V and GND line from the factory harness to power both amps?
A couple of ideas:
A couple of ideas:
- Contact Metra to see if they can provide a part number for the pins since they manufacture that bypass harness.
- Look for an old harness that matches amp pins and pull the pins from it
- Cut the wires from both factory and bypass harness and make your own harness. You could probably use headlight pigtails for that.
@MasterWayne
A couple of ideas:
A couple of ideas:
DC turn on can be set to 12v or DC offset.
@MasterWayne
I understand the Auto Turn On feature on those amps. I was just wondering why you insist on using those pins, but it makes sense if you want a plug-n-play solution so you can just go back to the factory amp quickly.
Personally, I would just cut the 12V and ground from the factory harness and connect them to the amp by either bullet connectors, soldering, or a two pin connector. You could solder those two wires back into the factory harness when you're done just as easily.
@MasterWayne
In red are the pins I need
marxw13
Jul 13, 2017 01:15 AM
803Twon302
Nov 28, 2008 09:26 AM
