Alpine PDX1.1000 goes into protection.
Old 08-06-2008 | 03:25 PM
djspot's Avatar
Ok so I got an Alpine PDX 1.1000 and an Alpine Type X 12" sub, 4ohms
The amp is stable to 2ohms and I got the jumper settings on my sub to deliever the 2ohms.
I have it connect using navone LOC.
My gains arent turned up past the 0 position...however if I turn up the gain any more than that the amp will go into protection if I have a song that hits any deep bass tones...
I called Alpine and they said one of my coils can be messed so I measured the impedance and it was reading 3.8-9 ohms at each coil and once wired a 2ohm load was being put to the amp.
Any idea, I've heard some people say it could be my ground, I've heard adding a capacitor my help because what can be happing is that my charging system cant keep up with the the power drawn by the sub hitting the deep tones and in turn causing the amp to go into protection...
I also heard it can be bad RCA's that can cause an amp to go into protection.
Any ideas anyone?
another quick thing, I dont know if this is normal but, I measured the load when the sub was actually playing and the load at the amp would drop below 2 ohms when the bass would hit, is that normal???
oh yeah, as far as my wiring...Im running 4 gauge power and ground, and I have 0/1 gauge at the battery to chassis ground
Old 08-06-2008 | 03:31 PM
Stew4HD's Avatar
It sounds like the amp is being over-driven. Could be something with your LOC bu tyou said the load changes when the deep bass hits? The load should be constant with only the voltage or current changing.
Old 08-06-2008 | 03:37 PM
ac08odl's Avatar
ON DA LOW CAR CLUB
Try Checking The Ground And Put It Somewhere Els.. I Dont Thing Its The Rca.. The Amp U Got Is A Mano Or 2 Chan.?
Old 08-06-2008 | 03:39 PM
ac08odl's Avatar
ON DA LOW CAR CLUB
Also When The Bass Cuts Out Is The Amp Really Hot?
Old 08-07-2008 | 02:40 AM
djspot's Avatar
it will cut out regardless of the temperature...if I went out there right now and turned up loud it will cut out. Thing is sometimes it cuts out within minutes or like 20-30 minutes later...
I'm going to sand down my grounding point really good, and see if there's a change.
As far as the load changing, Im gonna make sure and measure it again, and make sure Im measuring right...
thanks for the help so far guys...in the mean time I installed the aspec front lip today
Old 08-07-2008 | 02:32 PM
ac08odl's Avatar
ON DA LOW CAR CLUB
this happen to me b4. try making sure your ground is in the - slot in the amp and the power is in the + that can cause the amp to do that. also check all the fuse's... how did you wire these subs?
Old 08-07-2008 | 08:27 PM
djspot's Avatar
yup the ground and power are proper...I just finished really getting rid of all the paint at my grounding point for my amp, unfortunately I didnt have the change to really crank up the system because its a bit late right now.
I'll see how things go on the way to work tomorrow...
as for the fuses...my amp has 4 25 amp fuses, they're all good. I have a 100amp anl fuse at the battery and thats good too.
Im really hoping it was the ground
Old 08-08-2008 | 04:01 PM
BukvaMan's Avatar
from what i know on that AMP is that it delivers 1000 watts at either 2ohm load or 4ohm load. And since ur sub is a 4ohm u should set ur amp to 4ohm and not 2. If you are using a loc, the gains on it might be to high. i would try lowering them a little and then bring the gain on the amp to match the 1000 watss or less. U are probably clipping the amp it overheats and cuts out.
Old 08-08-2008 | 04:03 PM
BukvaMan's Avatar
sorry i did not read the first post right....
Old 08-09-2008 | 12:16 AM
tech14's Avatar
2008 NBP TL
If the amp loses power, and shuts off completely when it cuts out, it may be the battery. If the amp stays on when it shuts off it may be to another issue.
Old 08-10-2008 | 08:26 PM
1FastVtec's Avatar
Disturbin' The Peace!
I would check the above listed. Somethings not right. Is it still under warranty from Alpine?
Old 08-11-2008 | 04:41 AM
tech14's Avatar
2008 NBP TL
^^What can I tell Acura? All my other functions are completely normal, car starts, etc. I don't think they are going to replace a battery that won't power up my aftermarket system. My battery metered at 12.73 vollts, but no voltage was going to my amps.
Old 08-11-2008 | 10:30 AM
djspot's Avatar
So I figured it out...my amp has a switch that toggles between to voltage input settings 0.1-1V and 1.1V-8 or 9v...
I had it set to 1.1-8v, I switched over to 0.1-1, adjusted the gain and havent had any problems and the sub is hitting REALLY hard, and for long periods of time...so we're good
thanks everybody for all the help and ideas...
Old 08-27-2008 | 08:18 AM
wuiwui85's Avatar
Boosted...
I have the same problem as djspot but I have a pdx4.100 but i cant lower the voltage input settings like he did,I look it up can it maybe be something with HP LP settings, I also tried a new battery optima yellow top didn't make a diffrence??????please help
Old 08-31-2008 | 09:18 PM
Distorted Reality's Avatar
iScrape going into
hey just so you know your subs reading should not be jumping from 3.8 to 9 ohms
and wuiwhui85 take a mulitmeter and test the ohm load on from the speaker out put on the amp and make sure that your speakers presents a proper ohm load on the amp.
yahelou
09-06-2015 09:12 PM
StreetEffectz
05-09-2002 12:04 AM
CarFreak_RENAMED
02-12-2002 03:49 PM
Quick Reply: Alpine PDX1.1000 goes into protection.
