all you JL junkies please chime in.
#41
i believe ive heard them before in a buddies car.
ive always wanted JL tho. i used to have a 2 box setup with a bunch of amps that some dude GAVE me when i stopped and called 911 when he rolled his civic (fell asleep and flew 300 feet off a mountain side) and i gave him a ride home.
and i sold the whole setup for 100$ not knowing what it was worth. and this was before i had a car too so it really didnt matter.
#42
Rockford Fosgate Power T500-1bd Mono subwoofer amplifier 500 watts x 1 at 1 ohm - Rockford Fosgate
In Stock
Shipped from: DiscountJungle
$291.95
JL AUDIO 10W6v2 - Car subwoofer driver - 10" - JL Audio
In Stock
$279.95
Rockford Fosgate PEQ Amp Remote Control For 2007 Power and Punch Series amps - Rockford Fosgate
In Stock
$23.95
PAC SNI35 Adj Line Out Converter - PAC
In Stock
$12.99
thats what i ended up buying
In Stock
$291.95
In Stock
$279.95
In Stock
$23.95
In Stock
$12.99
#45
Driven to Perfection
That RF Amp is rated 500w at 1ohm, but the 10w6 is a DVC 4 ohm sub. That means it can be wired for either 8 ohms or 2 ohms. But at 2 ohms the amp is going to put out 400w. That same website has the JL A1400, rated 500W RMS @ 4 ohms on closeout for $219. The difference between 400 watts and 500 watts isn't enough to double your volume, but you will appreciate the additional headroom (at a savings!)
#46
^i really didnt understand what u were trying to say lol.
i planned to run the RF amp at 2 ohm 400watt.
the specs on jl said that the 10w6v2 is a 2 ohm amp;hence why im going to run 2 ohms at 400watts with the rf amp.
i used my amazon card cause i had some cashback and free shipping,so thats why i did it. amazon didnt have any 400 or 300 watt mono jl amps or i would have bought it,they only had the 500/1 jl amp and it was 100$ more,plus more wattage than the speaker should use according to the jl site.
it says the 10w6v2 should have an optimum wattage of 400.
i think ill be happy regardless. i agree 300 for a speaker is alot,but ill never buy another system as long as i own this car more than likely.
#48
ok so i screwed up...i thought i read the 10w6 is a 2 ohm but its actually a 4 ohm...now,i got the rf amp thinking i was going to use it at 400W@2ohm....is this possible without fucking up the speaker?
it was an error on my part cause i SWORE it said the speaker was a 2 ohm.
also,is the speaker i got the 10W6V2-D4? because it looks like there is a 10W6V2 and a 10W6V2-D4 which im not seeing the non-D4 on the JL site...?
#50
#51
I ended up wiring mine at 8ohms because I was told I might get better SQ that way. Now they're bridged so they're at 4ohms at the amp and I couldn't be happier. My super old Infinity amp is pushing them no problem.
#55
ok,all i had to do was go to the owners manual for the W6 and i got this :
Diagram B: Parallel Connection (2Ω):
Use two jumpers... one from “VC1–” to “VC2–” and
one from “VC1+ to “VC2+”.
thanks for all your guys' input and help. i kinda feel like a noob for once about cars,its not normal for me lol
#58
Good luck with your install. Take pics and keep us posted
#59
^thats a big 10-4.
thanks again for all your guys help. ill prob have the instal finished by the end of the month. i have alot going on cause im actually in the process of moving homes and storage so i gotta get the time to install and get a box,if i dont make my own ill have to buy one from travis.
the amp and sub should be here by next wed.
ill keep u updated!
ill keep u updated!
emailnatec
29
09-28-2018 04:27 PM
