Alarm Chirp (Speaker relocation)
Old May 28, 2008 | 08:53 PM
gumby430's Avatar
I know many people are upset because the lock chirp is so quite. I just wanted to share a success which i found in the forums. I pulled the alarm horn out of the wheel well and relocated it to the front bumper. It by far is not a loud as an after market alarm but it is much louder that it was. I am mych happier that I was with the chirp!!! Very easy to do. Open the wheel well on from left tire. Clip the wires for the horn and remove the one bolt holding the horn. Pull the wires bact into the engine comp. by the battery. Use some 18 g wire to extend it to the bumper. Used some zip ties to hold it in place. I suggest this for anyone as annoyed as I was.
Old May 28, 2008 | 09:17 PM
drdamian's Avatar
FOR SALE - BM
good advice, im going to do it next time i take my bumper off. i always thought that chirp was way to low and i would usually just hit the lock button on the remote a bunch of times.
Old May 28, 2008 | 09:45 PM
gumby430's Avatar
No need to take the bumper pff. Just rerun the wires to the side of the rad.. and zip tie it the the post right behind where the front plate woulld go. There is a perfect place for it and it will keep it out of the rain. The hardest part was getting the speaker free from its factory spot. You will need some patience.
Old May 28, 2008 | 10:40 PM
ABP_04TL's Avatar
6-SPEED LOVER
any chances i could make my horn sound instead of that beep?
Old May 28, 2008 | 10:47 PM
lamv225's Avatar
What is the feasibility of replacing the factory alarm horn with an aftermarket one?
Old May 28, 2008 | 11:45 PM
phee's Avatar
I got the Shifts
you could amplify the sound by using another speaker...
Old May 28, 2008 | 11:49 PM
RedAggie03's Avatar
I used to own a
I'm amazed how quiet the chirp is, but how loud it is when the alarm goes off...
Old May 29, 2008 | 10:54 AM
robbie82's Avatar
Cablevision Employee
Not a bad idea...
phee are u sure a new speaker would make it louder? What makes u think the amplification is enough to make an audible difference on an after market speaker?
Old May 29, 2008 | 08:25 PM
gumby430's Avatar
An new speaker I dont think will make it louder. The volts are very low which make the chirp so low. You would neet to boost the volts to 12v and get a new speaker because the factory would burn up with that many volts.
Old May 30, 2008 | 10:18 AM
jimsta's Avatar
NTMD8
Wow... the alarm chirps... I can't hear anything beeping or making sounds and I am standing right next to the car... i guess i iwll try listening closer to the hood next time.
Old May 30, 2008 | 10:50 AM
blkaspec's Avatar
Full of water...
you have to hit "lock" twice on your fob to hear it
Old May 30, 2008 | 11:04 AM
jimsta's Avatar
NTMD8
Dang.. I did not know that... is there any kind of beep that lets you know the doors were unlocked as well?
Jul 16, 2017 07:33 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
polish_pat
Sep 25, 2015 12:24 PM
