Advanced loc and remote help
Old Apr 29, 2012 | 10:38 PM
shawn_vs's Avatar
Hey guys heres the problem, i got a 4ch and a mono installed, they work fine except i have the amp turn on from the fuse box,and my loc (cache oem6) has a auto remote turn on. some times when in my car i like the volume to be off but i get a hiss. I tryed lowering my loc and putting up the gain on amps. But nutting works ither i get really low sound or its not loud enoughf. Is there a way my amps can turn off when i turn the deck off what wire to tap in to? I bypassed the factory amp and with the factory amp output it sounds bad. I have a 3 sixty.1 that i tryed to use but i didnt like the way it sounded and its really hard to use the software it keeps crashing. Please some advise this hiss is really annoying thanks aziners
Old Apr 29, 2012 | 10:44 PM
Trunk Monkey's Avatar
Coolest A-zine Member
That is your ONLY option right now.
We have a balanced signal and unless you have these 3 things:
1. Amp that accepts balanced
2. Processor
3. Balanced Line Driver
You're going to get noise
Old Apr 29, 2012 | 11:38 PM
shawn_vs's Avatar
Should i use my rockford 3sixty1 would that help the pronlem my amps are alpine mrp f600 and mrp 1000? Thanks trunk monkey is it possiable to have the 4ch come on and off with the deck on/ off button
Old Apr 30, 2012 | 12:03 AM
I hate cars's Avatar
Try unplugging the RCAs from the aftermarket amp. If the hiss is still there, it's an amp issue. Usually the hiss is from taking the signal from the stock amp and sending it through a LOC to the aftermarket amp but you said you're taking the signal pre-amp. Post amp, there's nothing you can do, you will have hiss.
If you have no hiss after unplugging the RCAs, hook one item back up at a time. The LOC, then the inputs to the LOC or line driver, or 3sixty or whatever you're using at the time.
I seem to remember some of the original 3sixties having high noise floor issues.
Old Apr 30, 2012 | 12:12 AM
I don't think that's one of the amps that has the noise floor issues but the PDX amps had a bad hiss problem. You might want to ask around about the amp itself if the hiss remains after disconnecting the RCAs.
Most of the noise I've encountered when going pre amp is alternator and ignition noise, not hiss.
Old Apr 30, 2012 | 02:17 AM
JR2586's Avatar
line drivers are soooo important!!!
Old Apr 30, 2012 | 09:23 AM
shawn_vs's Avatar
Thanks im going to try it now
rockyboy
Aug 4, 2024 10:35 AM
Cexarin
Sep 23, 2015 07:43 PM
g1underground
Mid-Atlantic
Sep 23, 2015 01:18 AM
dirleton
Sep 21, 2015 01:42 PM
alan_rich
Sep 7, 2015 11:08 PM
