Adding aftermarket amp to power stock speakers
Hi Guys,
I know this topic has been discussed already but I didn't want to hi-jack anyone's thread so I thought I start m own for a little input. I'm also a newbie and would getting help from a friend who runs a stereo shop.
I don't want to add a subwoofer or lose the center channel. Some of the other posts have mentioned if I removed the stock amp, I'd lose the center channel and the navi prompts would have to be routed to one of the other speakers.
This is what I'd like to do. Add a aftermarket amp to power the stock speakers with no intention of adding a sub or losing the center channel. I just want a cleaner sound with a little more bump.
1. Can this be done with just adding an amp and keeping the stock amp?
2. What amps do you guys recommend? I been hearing good things from the Rockford Fosgate PBR300X4.
Let me know if there's anything else I should know.
Thanks!
Thanks!
I am no expect but willing to help. The PBR300x4 is a four channel amp. You can get 2 amps. One 5 channel for the four speaker and sub., one 2 channel for the center. FYI. Replacing the amp without replacing the speakers is not a big improvement in sound.
Can I hold onto the stock amp for for the center channel?
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/mild-grade-fever-854353/
My build thread. all your questions have been answered numerous times in different build threads. keep center and rears on OEM amp. add 5 channel amp. bridged or active to the front components and sub.
https://acurazine.com/forums/showthread.php?t=854353
I'm still confused on why 5 channel amp if I don't want to add an aftermarket sub. I'm sorry.....I'm a stupid newbie.
Less the IB baffle fabrication, that is actually one of the simplest builds to obtain quality sound that you will find. replace OEM speakers with quality components and add a amp that works well with the acura HU. Trust me you will want to upgrade your sub. you could get by with a 2 channel, but why limit yourself? when you decide to upgrade later it will just cost you more money.
Hi Guys,
Thanks!
Thanks!
As for me I current have 3 amps in my system and an Audicontrol Matrix line driver. First amp is for my front stage, front doors and tweeters. The second amp is for sub and the last amp is the factory amp which is for center and rears. All aftermarket speakers and amp where wired with Stinger cable and doors and trunk sealed and deaden. all I've spent about $1500 which is not much since I've reused a lot of my components from previous installs. So just a warning once you start your probably gonna keep on going.
handsom-hustla
11-13-2015 05:04 PM
Pegon95
09-15-2015 01:54 PM
trinikidcl
09-04-2015 12:56 AM
