55w HID's
Old 06-14-2014 | 02:14 PM
Bswain321's Avatar
55w HID's
Was wondering if anyone is running 55W HIDS in their headlights or fogs? And if so any issues?
Old 06-14-2014 | 03:07 PM
I'm sure peopl ehave but to be honest, is it really necessary? Acura OEM ballasts are some of the most outstanding in terms of brightness and longevity. Get some CBI's in there and maybe clear your headlamps if its blurred over. 55W bulbs and ballast tend to burn out faster due to the higher wattage = more heat.
Old 06-14-2014 | 03:40 PM
Bswain321's Avatar
What exactly are CBO's? I was just wondering. I want to get a brighter bulb.
Old 06-14-2014 | 04:33 PM
Nick216's Avatar
The Boss
Osram CBI is a 5k bulb, one of the highest lumen rated bulbs for 5k color.
Old 06-14-2014 | 05:29 PM
Bswain321's Avatar
Where can I get this? And is it dual beam? And can I get them for the fog lights?
Old 06-14-2014 | 06:52 PM
Nick216's Avatar
The Boss
There are just headlights. There quite expensive at 185$
Old 06-14-2014 | 07:57 PM
Bswain321's Avatar
I found them. I'm guessing they are high / low beam?
Old 06-14-2014 | 08:55 PM
paperboy42190's Avatar
your high beam is integrated into your projectors. you only need a d2s bulb
Old 06-14-2014 | 09:04 PM
Bswain321's Avatar
I know the factory is. I figured that these are also all together
Old 06-14-2014 | 10:29 PM
ChuckP's Avatar
Using 55w in headlights. No problems
Old 06-16-2014 | 02:43 PM
VanyDotK's Avatar
Using 55w bulbs with 35w ballast is useless. If you're going to get 55w bulbs make sure to get 55w ballast to match. I had Phillip 55w with 55w ballast in my s2000 retrofit and it looked great, but not worth the cost.
Old 06-16-2014 | 03:07 PM
Bswain321's Avatar
If I was doing 55W I'd obviously get both ballast and bulbs at 55W.
Old 06-16-2014 | 03:18 PM
Nick216's Avatar
The Boss
If you want to risk melting your thousand dollar headlights, go for it. Osram CBI with zkw lenses. It doesnt get any crisper and brighter than this, without risk.
VanyDotK (06-16-2014)
Old 06-16-2014 | 05:33 PM
ChuckP's Avatar
lol @ melting housings
Old 06-16-2014 | 05:38 PM
VanyDotK's Avatar
I ran 55w blast ballast and bulbs for 2 years without any problems. As long as you use good bulbs you should be give, don't use cheap branded bulbs.
MilanoRedDashR
10-08-2015 10:30 AM
mshipon
2G CL Problems & Fixes
09-28-2015 12:14 PM
MilanoRedDashR
09-27-2015 10:15 PM
h22lude
09-27-2015 06:22 PM
Quick Reply: 55w HID's
