4 ch amplifier install question
Old May 4, 2005 | 09:50 AM
bklynpanman's Avatar
321 whp SAE
Has anybody installed a 4 ch amp and replaced the speakers? I want to know what kind of low input converter was used. When i installed my sub, i couldn't use the preamp lines to get a signal, I had to use the lines coming out of the stock amp.
Old May 5, 2005 | 07:50 AM
rickneuropa's Avatar
Do a search, but I believe the concensus is, the lines going into the factory amp, is low level, so if you want to wire in some RCA's to them, and go directly into your amp (if it has adjustable gains) you should be good to go.
Old May 5, 2005 | 12:28 PM
321 whp SAE
if it didn't work on the sub line, i don't know why it would work on the speaker lines
Old May 5, 2005 | 04:16 PM
It should have worked on the sub line. Are you taking the lines from the input to the factory amp? again, these would be low level, not speaker level, so they would go into your amp in the RCA low level inputs, then adjust your gains accordingly. That is if your amp's input gain is adjustable.
Old May 5, 2005 | 08:14 PM
321 whp SAE
yes i took it from the lines before the factory amp.. tried 4 different converters.. nothing...
Old May 5, 2005 | 09:44 PM
You shouldn't need a converter really, just wire in RCA plugs.
Feb 25, 2020 09:57 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
Skirmich
Sep 15, 2015 06:41 PM
datadr
Sep 12, 2015 09:12 PM
