3G TL climate control and gear shift lights out
Old Jan 17, 2015 | 03:57 PM
Ruhroh's Avatar
My initial thought of course is that there is a bad fuse, but I can't determine which fuse is appropriate. Does anybody know exactly which fuse I need to check?
I should add that I have an aftermarket stereo that was installed before I purchased the vehicle. Is there any chance that the removal of the OEM deck has something to do with the lights being out?
I do understand from browsing the forums that these bulbs sometimes fail, but because they are uniformly out, I suspect I should check the fuse first.
Thanks in advance.
Old Jan 17, 2015 | 08:02 PM
Ruhroh's Avatar
Anyone? :/
Old Jan 20, 2015 | 03:14 PM
FZ427's Avatar
Might be the lights, happened on my 04 TSX the shight light one.
Old Jan 20, 2015 | 03:33 PM
Ruhroh's Avatar
Thanks - I suspected that after seeing all the posts about lights going out ... sometimes intermittently.
I've ordered some T3 LEDs and will try to install them today.
Old May 12, 2015 | 08:24 PM
wusty23jd's Avatar
Yeah for whatever reason, the OEM bulbs are very cheap and tend to go out all over the interior. I'm in the process of changing as many bulbs as possible to blue and white LEDs. Some of the bulbs are very easy and some are almost impossible to change unless your an experienced solderer.
Old May 12, 2015 | 08:25 PM
wusty23jd's Avatar
I plan on changing my gear shift bulb within the next few days. There are is a great Youtube video showing how to do this.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
PortlandRL
Sep 14, 2015 12:01 PM
HeloDown
Sep 8, 2015 06:51 PM
