2ohm components that fit?
Old 09-04-2014 | 11:30 AM
nosstang's Avatar
Anyone know of some 2ohm components that will fit in the doors of the 05TL?
Old 09-04-2014 | 12:05 PM
blownby's Avatar
Just did the polk audio mm 6501's.
You have to cut the door skin(metal a tad as these are 6 3/4".) But very simple and fit great behind door panel still
Think they are like 2.7 ohm's
http://www.sonicelectronix.com/item_...io-MM6501.html
nosstang (09-04-2014)
Old 09-04-2014 | 12:21 PM
nosstang's Avatar
Im running the stock system on a 5 ch JL amp, I wounder if the 2.7ohm will be safe
Old 09-04-2014 | 12:58 PM
blownby's Avatar
is the amp stable at 2 ohm? I'd assume thats why your asking for a 2ohm component?
Old 09-04-2014 | 01:49 PM
nosstang's Avatar
Yes the 5ch JL amp is calling for 2ohm components. I blew out the stock ELS speakers in the doors so I was looking to replace them.
Old 09-04-2014 | 04:29 PM
nosstang's Avatar
I pulled the trigger and bought the mm 6501's. How did you modify the door? just trace the outline of the 6501's and trim the metal? Did you have to modify the door panel?
Old 09-04-2014 | 07:52 PM
csmeance's Avatar
Infinity makes some 2ohm speakers that fit without any modifications as far as I know
Old 09-05-2014 | 09:30 AM
blownby's Avatar
I am using the alpine 5 ch amp..PDX v-9, works great!
I had a hole saw that was the same diameter cutout, i traced. I'm sure you can use the mount ring as well as that should have the same cut out dimension.
Score a line, then cut out with a jigsaw. File done rough edges. Really easy.
Door panel fit back perfect w/o issues. I removed the plastic mount the oem speaker was in. I also sound deadened the door panel as well as the door skin. Just check the way you locate the screws for the speakers so you don't hit any hthing on the back side like wire harness or window brackets.
emailnatec
29
09-28-2018 04:27 PM
InFaMouSLink
10-30-2015 09:43 AM
Bielikb96
09-28-2015 10:45 AM
Quick Reply: 2ohm components that fit?
