2007 TL Horn no workie
Old 05-12-2015 | 12:20 PM
shreve66's Avatar
9th Gear
I have looked and looked, researched for hours. WHERE ARE MY HORNS LOCATED???
I don't have a repair manual, but even looked at them online. I believe the horn on the driver;s side is located near my front driver side tire under the plastic cover.
I removed the cover and I can see the fog light. I also see this black cylinder looking think that has a plug connected to it. It looks nothing like any horn I have seen online. I am so confused. Please help me.
Old 05-12-2015 | 12:22 PM
that black cylinder looking thing with the plug connecting to it is the horn
Old 05-12-2015 | 12:55 PM
shreve66's Avatar
9th Gear
Im going to upload a photo of it. It just doesn't look anything like any horn I have seen. I have read everywhere that the chasis grounds it, but the plug has a hot and a ground wire. I just want to be sure. I know I sound like an idiot, but I just cannot find any videos or instructions on this. I am ready to replace the horn, but which one is on the left side, the high or the low.
Old 05-12-2015 | 03:19 PM
polobunny's Avatar
Registered Bunny
Old 05-12-2015 | 03:48 PM
shreve66's Avatar
9th Gear
Ok, so what I removed def isn't the horn. Thank you for helping me. Do I need to remove my tire? Has anyone done this before? I will post the thing I removed. I'm such an idiot. I can work on 60 million dollar aircraft for 18 years, but I can't replace my own horn. Wow
Old 05-12-2015 | 03:51 PM
shreve66's Avatar
9th Gear
Def not the horn
polobunny's Avatar
Registered Bunny
Happens to the best of us. Not sure what you removed, but you might want to put it back.
Old 05-12-2015 | 03:57 PM
OP you should be able to just work through wheel well, removing tire might just make it more convenient
Old 05-12-2015 | 04:18 PM
polobunny's Avatar
Registered Bunny
I just noticed you posted pictures of what you removed. You removed this from the wheel well on the driver side behind the front axle (closer to the door than the front of the car), yes?
That looks like the keyless buzzer. When all doors are closed and you lock your car with the fob and press the lock button again (2 times in quick succession) you'll hear a beep. With this removed, you won't.
Old 05-12-2015 | 05:26 PM
shreve66's Avatar
9th Gear
I pulled the keyless buzzer. Now I'm going to search for the unicorn, I mean horn. Where is it? Does it even exist?
Old 05-12-2015 | 05:53 PM
shreve66's Avatar
9th Gear
Old 05-12-2015 | 05:54 PM
shreve66's Avatar
9th Gear
The picture is not accurate!!! The horn on the passenger side is right behind the fog light and not next to the blinker like the above photo shows.
Old 05-12-2015 | 06:43 PM
polobunny's Avatar
Registered Bunny
Should I assume you've found it, this time?
It's possible the location is slightly different, since the screenshots come from a 2004 Acura TL manual. A strange thing to move, but I imagine there was a good reason according to Acura.
Old 05-12-2015 | 06:53 PM
shreve66's Avatar
9th Gear
Found them both!!!!!! They are on the passenger side right behind the fog light. Disconnected one of them and didn't hear a difference. Will troubleshoot some more tmr. I'm going driving for Uber now. Thanks for the help.
Old 05-12-2015 | 07:24 PM
guitarplayer16's Avatar
From my experience from installing fogs, 2004 TLs have it on each side, whereas 05 and up have both located right by the washer reservoir on passenger side.
Old 05-12-2015 | 09:20 PM
shreve66's Avatar
9th Gear
That would have been nice to know before I tore my car apart. I was beyond frustrated. Now I just need to order a new one. I'm going to remove it and try to fix it. These things are expensive.
Old 04-14-2018 | 05:52 PM
englundg's Avatar
3rd Gear
2008 TL horns behind bumper
Both horns for the 2008 TL are behind the bumper on the passenger side. All the posts I can find say you can reach them from the wheel well but, while you can see them, it is not possible to get a wrench on them without taking the bumper off. I can't do that without some extra help so I had to put it back together and wait until another time. Very frustrating. Even with the bumper off it appears that there is not much clearance.
08KBP_VA
10-22-2019 02:55 PM
MetalGearTypeS
08-29-2016 09:28 PM
blacktsxwagon
10-27-2015 11:12 PM
jubikej
1G RDX Problems & Fixes
09-30-2015 02:13 PM
07Acuradude
09-29-2015 04:01 PM
Quick Reply: 2007 TL Horn no workie
