2007 Acura TL Navigation System
Slicker Than Your Average
Is the Acura Navigation System in the 2007 Acura TL the same as the one in the 2007 Acura MDX in terms of version, resolution, features, etc.?
the 07 is slightly diffrent has it has they joystick instead of the touchscreen. It does not thave the audio menus at all. Thats as far as I know.
The Acura Navigation System in the 2007 Acura MDX doesn't have the audio menus? Is the Acura Navigation System in the 2007 Acura TL the most current version?
yup so far to my knowledge, the RL might come in but it has that joystick knob thingy. I thing the TL and TSX are the only touchscreens left in the acura lineup. MDX has controls for the audio on a seperate screen.
I have a 07 tl.... yes it does have the joystick and touchscreen..... although the real time traffic is totally unuseful ... stuck in traffic all the time in metro areas where it surpose to work best
1 Post
07 NBP TL-S
07 Navi button sensitivity issues
Anybody notice that the navi touch screen buttons seem a little off?
My 06 navi was accurate and sensitive to exactly where I touched. On my 07 I have to "press" the button multiple times or touch the button in different places to activate it. I may be going to the dealer to have this looked at.
1 Post
Originally Posted by Abeyance
I've noticed the same thing on my '07 as well. It's quite annoying, especially when an adjacent button gets selected when I know I didn't hit that button.
#include
The first few times I just figured I had mis-poked. Like many others here, mine is off. I have found that aiming slightly above the one I'm aiming for usually does it.
07 NBP TL-S
Originally Posted by lithiumus
I forgot which 3 buttons to press, but you can calibrate this in the config menu...
07 NBP TL-S
TO FIX TOUCH SCREEN:
push MAP/GUIDE, MENU and CANCEL for 5 seconds together at the map screen
There should be an option for MONITOR CHECK
Then use the TOUCH PANEL CHECK OPTION FIRST
see if it works properly
then use the TOUCH PANEL CALIBRATION option to calibrate it to you fingers.
My new 07 is off as well. Only on one column of letters. It's when I hit "S" in the middle, the "T" registers and whatever letters are above and below the "S". The dealer is checking it out tomorrow when they install wheel locks, mats, trunk tray. If that doesn't work, I'll try above myself.
Fix
What is the difference in "TouchPanel Check" option and "TouchPanel Calibration". The screen that she had left on when I got my car back was a bunch of small square boxes. I think it was the "Check" screen, but that wouldn't change anything. I would assume I need the Calibration option. If so, what does that involve? Is it like PDA's where you touch certain crosshairs on the screen?
DIY Mad Scientist
ok... Calibrate option to "Calibrate", Check option to "check". After you calibrate it, check it so that you know the touch screen works properly.
Play around with the calibration by pressing and holding one of the 4 squares on the screen and moving the joystick... you'll figure it out.
Went to Touchscreen calibration. Saw (4) square with "+" next to each. Pushed square, it lit up, tried to move joystick and nothing happened. So I pushed joystick in while holding finger on square for each square. (Screen said "Push map guide to reset parameter. Push Joystick to set it). Pushed "Return". Went to TouchPanel check and now, with pen tip, every thing I push registers the tiny square to the left of what I push.
Weirdest part is I am no longer having the problem inputting address or store name. If I press "S" is brings up "S". Did if fix it and screw something else up by accident since "TouchPanel Check" is off now?
Originally Posted by johndawg
I followed the instrutions in post #17 and my touch screen is working fine.
Thanks!
Thanks!
Originally Posted by reisb
I just don't understand what the "+" vs. "blank boxes" are for. If I knew if I should be pressing the + or the blank box and the purpose, it would make more sense to me.
Once you have determined that your calibration is off, use the TOUCH PANEL CALIBRATION option to calibrate it to you fingers
John
The "blank boxes" are for testing to make sure the calibration is set.
John
John
So I pressed the right side of screen "+" and moved joystick to the left 2 clicks. set it and it works better. But I don't know why that worked better. Almost like I was adjusting the touchscreen left some. hmmmm.
rockyboy
01-25-2016 06:00 PM
travr6
09-06-2015 02:11 PM
2004, 2007, acura, calibrate, calibrating, calibration, fix, navi, navigation, problem, screen, system, tl, touch, touchscreen
