2004 TL Audio problem--non nav TL
Old May 28, 2019 | 04:03 PM
Joeyo's Avatar
Exclamation 2004 TL Audio problem--non nav TL
My radio has suddenly lost most of its volume on all settings AM and FM .
Also I do not get any sound at all from the CD unit. I can see the unit actually playing the disc with the time remaining showing etc. It also changes discs normally. After reading posts I feel the amplifier behind the passenger kick panel is probably causing my problem. The CD problem is not mentioned in the posts and is the part that is worrying me.
What do you think, or better yet, know about this? Looking for all suggestions before buying a used OEM amplifier.
Old May 28, 2019 | 04:20 PM
https://acurazine.com/forums/3g-tl-a...volume-922588/
Old May 29, 2019 | 08:32 AM
Jackass's Avatar
If there are major volume differences between inputs, it isn't the amp, it is the HU itself. If all inputs give the same lack of sound, most likely the amp.
The easiest swap/test is to replace and/or repair the amp. They are known to fail with age and there are guides on how to replace the most likely failed component which are the capacitors.
eighch
18
May 5, 2018 06:45 PM
lukelikespizza3
Nov 5, 2015 01:05 PM
Slobo7x
Jul 16, 2013 09:34 AM
wmb0000
Feb 18, 2010 02:43 PM
e30cabrio
Sep 19, 2008 03:35 PM
