100% Plug And Play Navi Conversion
SOKOLOV Finally come out with the plug and play using original Acura plugs he tested it in my car it was sweet he unpluged the 20pin connector from Navi DVD ROM and plug it in to his hanress and used the other side of the harness to plug it in to the navi dvd rom took about 10 seconds and you are ready connect the ground and positive add a video source(dvd, backup camera,ps2) and enjoy the awsome quality of the NaviPlus converter. Check out the group buy he got going.
https://acurazine.com/forums/sponsored-sales-group-buys-10/100%25-plug-play-navi-dvd-oem-style-plugs-287460/
Its not that cheap.. I still think I would go with AV Electronic unit. You still need to buy a AV switcher. The AV Electronic unit already has 4 AUX outputs incorporated into the unit.
Yeah $100 for a plug. That is crazy. I can see $25 or $50.
Please dont froget that sokolov's unit has better quality than avelectronics you dont need a switcher just buy an icon dvd with three video inputs it only cost 130 shipped on ebay and I have all the sources wired through it. Plus sokolov's plugs are actuall Acura plugs which he said costed about 50 dollars for each just in lawyers fees to get premision from Acura and dont forget if enough people buy its only 50 dollars more.
Computer Techie Geek
ok Call me DUMB .... Please let me understand how this works ...
basically VSOKOLOV's unit Gives you a(n) Video IN (only) and uses the LCD buit for Navi for various sources... correct ??
How about audio ? can I have 5.1 Surround Sound of my DVDs as well ?
Team Anthracite Member
No, you can't get 5.1 surround cuz there's no way to get a 5.1 audio feed into the head unit. Well, unless you were to take it apart and find where the signal gets fed into each preamp, but that would be insane.
Best that can be done now is a 2.0 audio feed using a Blitzsafe adapter, but it means some fancy wiring to include XM (if you're in the US).
Sokolov's unit gives you 1 video in and plays that video on your Navi screen. That's all it does. To add more sources or more outputs, you need an AV switcher. I bought the one he sells and it works perfectly. It even has 4 switched 12V power outlets to power the headrest LCDs or whatever else.
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
No, there are other ways to get sound. You can use an FM modulator, or a powered FM modulator. That works by broadcasting the sound onto a selectable FM frequency. It's not quite as good sound as with a direct AUX connection but it's a good choice for people in the US because the install isn't that complicated. If I were in the US, I would probably do the Blitzsafe thing. In Canada, Blitzsafe is a no-brainer. I have a feeling that the next generation of our head unit will have a very easy (probably RCA) AUX-in.
for group buy click here
Need four more people for vsokolov's Navi to Video Conversion Module group buy to get free shipping.
https://acurazine.com/forums/showthread.php?t=295859
Need TWO more people for vsokolov's Navi to Video Conversion Module group buy to get free shipping.
VSOKOLOV,
I have your unit from several months ago and I never installed it. I've been waiting for the Plug and Play piece. Can I purchase your PLUG AND PLAY WITH ACURA OEM CONNECTORS?
email me at sales@naviplus.tv
navtool.com
ILX Audio, Bluetooth, Electronics & Navigation
32
12-22-2015 12:46 PM
navtool.com
14
10-31-2015 08:16 PM
sockr1
10-01-2015 01:31 AM
