'05 TL HandsFreeLink Reset - New OEM?
When I got my TL the hfl was draining the battery and was bad. I replaced it with a used one but has a security code stored. I tried disconnecting the battery and touching them together as well as pulling the fuse. Neither worked. Called "local" Acura dealer and they wanted $125 to clear the code. Car is non-navi.
Is there anything else I can try? Or, if I buy a new oem one from dealer, will it have any codes stored?
Activate the HFL and say "system," then respond "clear" when given options.
On-line TL owner's manuals are linked at: J-020: 3G Acura TL Owners Manual, Navi Manual & Warranty Booklet PDFs .
A new HFL will not have any stored passcodes.
The only option I know of is to clear the HFL memory.
I might be able to get it, but after I tried calling Acura (the part that does radio codes and such) they said that they could not give me a code of anything to fix it. They told me the dealer would have to reset it. What did you have in mind?
number one never tell a dealer you bought a used part, that's why they are charging you due to liability.
just go to a different dealer, tell them you just bought the car and need the Bluetooth reset.
That's what I did when I first bought mine and they did it for free
If the exact language from the manual doesn't work to get around locked system, then try "0-1-2-3" or "1-2-3-4" to see if that saves you from a trip to the dealer.
Jul 16, 2017 07:33 AM
JDM96specCTR
Oct 17, 2015 01:06 PM
Hines57
Sep 24, 2015 01:58 PM
