05 mirror upgrade/// master wire guide
Old Dec 21, 2009 | 11:54 PM
dirtywop's Avatar
chris
installed 07/08 mirrors,, swap was easy, but the damn molex in the doors, taped into the turn signal wires , above the fuse box. here is the wireing guide if you need it..thanks
Turn Signal (Right) white + large white plug, top of fuse box
Turn Signal (Left) red/blue + large white plug, top of fuse box
Hazards green/red + large white plug, top of fuse box
Parking Lights (-) red/black - headlight switch in column cover
Parking Lights (+) red/black + large white plug, top of fuse box
Disarm Defeat yellow 5wi large white plug, top of fuse box
Unlock Motor yellow/green 5wi green plug, front of fuse box
Lock Motor yellow/black 5wi green plug, front of fuse box
Power Unlock pink/blue - green plug, left side of fuse box
Power Lock pink/black - green plug, left side of fuse box
fuse box, green plug above blue fuel
pump relay
Can Bus Sw brown/black (door lock data) data
Can Bus Low
Can Bus High
Data Bus red/blue or yellow (immobilizer data) data Immobilizer Module, pin 2
Key Sense red/white - ignition harness
Third Accessory
Second Accessory white/red + ignition harness
Accessory black/red + ignition harness
Third Ignition N/A
Second Ignition N/A
Ignition black/yellow + ignition harness
Second Starter N/A
Starter black/white + ignition harness
Second 12 Volts
12 Volts white (50A) + ignition harness
Item Wire Color Polarity Wire Location
Right Front Heated Seat
Left Front Heated Seat
Mirror Defroster
Rear Defroster
Fuel Pump
Clutch Pedal
Neutral Safety
Wait to Start N/A
Tachometer NOT yellow/black ac any fuel injector
Trunk Alarm Shunt
Disarm No Unlock see factory alarm disarm
Factory Alarm Disarm black/red to white - driver door module in door
Factory Alarm Arm blue/white to white/red - driver door module in door
Power Sliding Door (Right)
Power Sliding Door (Left) N/A
Fuel Door Release
Trunk Release Motor
Trunk Hatch/Release yellow/green or blue/black + driver kick, harness to rear
Hood Pin yellow/red or green/black - hood pin switch in latch
Rear Glass Pin
Trunk/Hatch Pin blue/yellow - green plug, left side of fuse box
Dome Supervision green/red - green 5 pin plug, rear of fuse box
Right Rear Door Trigger
Left Rear Door Trigger
Right Front Door Trigger
Left Front Door Trigger see notes - rear of fuse box
Reverse Light green + driver kick, harness to rear
AutoLights
Headlight black/red - headlight switch in column cover
Satellite Audio Right (+/-)
Satellite Audio Left (+/-)
Satellite Radio Antenna
Satellite Radio Ignition
Satellite Radio Ground
Satellite Radio 12 Volts
RSE Audio Right (+/-)
RSE Audio Left (+/-)
RSE Video (+/-)
Aux. Audio Input Right (+/-)
Aux. Audio Input Left (+/-)
Subwoofer (+/-)
Center Channel (+/-)
Right Rear Speaker (+/-) red/blue - yellow +,- stereo amplifier in passenger kick
Left Rear Speaker (+/-) brown/white - red/yellow +,- stereo amplifier in passenger kick
Right Front Speaker (+/-) blue - red +,- stereo amplifier in passenger kick
Left Front Speaker (+/-) lt. green - purple +,- stereo amplifier in passenger kick
Power Antenna yellow/green + radio harness
Factory Amp Turn-on red/yellow + radio harness
Radio Illumination red/black + radio harness
Radio Ignition yellow/red + radio harness
Radio Ground black - radio harness
Radio 12V white + radio harness
Memory Seat 3 N/A
Memory Seat 2 red/yellow - driver door module in door
Memory Seat 1 blue/yellow - driver door module in door
Sun Roof (Limit/Close) N/A
Sun Roof (Open/Close) motor part of module
Right Rear Window (Up/Down) red/white - blue/black A RR window switch in door
Left Rear Window (Up/Down) blue/yellow - blue A LR window switch in door
Right Front Window (Up/Down) red/blue - red A RF window switch in door
Left Front Window (Up/Down) red/black - red/yellow A LF window switch in door
Wipers blue (L), yellow (H) - windshield wiper motor
Horn Trigger green/yellow - horn switch
Parking Brake green/orange - large white plug, top of fuse box
Brake Wire white/black + brake pedal switch
Speed Sense blue/white ECM/PCM, gray plug, pin 11
here you go....
Old Dec 27, 2010 | 12:44 AM
tl206's Avatar
Does "driver door module in door" means it's behind the door panels?
Old Dec 27, 2010 | 08:51 AM
dirtywop's Avatar
chris
Yep.. Pull the panel ..
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
dirleton
Sep 29, 2015 08:26 AM
