04 TL fusebox and Escort Direct Wire... WTF?
You touch my tra la la...
Can someone explain to me how I get the direct wire into the fusebox? Instead of being a two pronged thing its like a square metal plug.
Check these posts...
http://www.acura-tl.com/forums/showt...stealth+Escort
http://www.acura-tl.com/forums/showthread.php?t=68622
I used the Add-A-Circuit and this is available only at Autozone... Could not find it at Pepboys or Kragen... When you plug in the Add-A-Circuit make sure that you put in two fuses into the add-a-circuit otherwise it will not work. I have copied the pictures of the Add-A-Circuit from the thread by nickpoore (Thanks Nickpoore for this info...)
![](http://www.nickandang.com/V1/V1Electrical03.jpg)
![](http://www.nickandang.com/V1/V1Electrical02.jpg)
![](http://www.nickandang.com/V1/V1Electrical04.jpg)
I went to PepBoys for that however they only had the normal sized one and we need mini fuses. How did you connect the end of the direct wire into the add-a-circuit?
emailnatec
29
09-28-2018 04:27 PM
xsilverhawkx
09-28-2015 06:51 PM
