'04 TL: 1/4" output from XM connector? Is there a cable available?
Old Jul 25, 2011 | 05:59 PM
Killabee44's Avatar
HI all,
I am a new TL owner looking to do my fist mod on an 04 TL without navigation...
After reading and searching the forums I have not been able to find an answer.
From what I understand, there is a way to get an aux input to the stereo through the XM connector.
I am not using XM on this stereo, so that would be great if a cable was available that I can plug in.
In one thread someone was talking about making your own. That thread was very old though, so maybe now there is a cable out there that I can buy.
Is one for sale somewhere? If anyone can help, please do. Thanks.
Old Jul 25, 2011 | 06:14 PM
Killabee44's Avatar
I forgot to mention that I will be sending the audio from a small mp3 player's 1/8 inch input (not 1/4 inch like I said before), so I need something simple.
I don't have or need an ipod, so this mod would be perfect.
Old Jul 25, 2011 | 07:47 PM
csmeance's Avatar
do you mean you will be using the headphone jack?
If yes, you can get a variety of adapters that can work. There are a few cheap ones and some more expensive ones. The XM mod is a bit more involved and requires an adapter rather than making your own cable.
Cheapest:
Tape Deck adapter, you can buy one at radioshack for a few dollars and it goes into the tape deck. A wire sticks out and you can plug that into the headphone jack in your MP3 player. -> Very Good Sound Quality!
2nd Cheapest:
FM transmitter, you can get them for around 20 dollars and hook it up to the MP3 player. Just go to the radio preset and your done. -> Okay sound quality
The costly one:
You can get an adapter that plugs in the back of the radio. You remove the XM plug and plug in the adapter, then you plug the XM cord into the adapter so you can still have XM if you want. The adapters range from 50 dollars to 300 dollars depending on what you want.
A few adapters you can get are the USA-SPEC, DICE, PIE X3, iSimple, and so forth. All of these will have an ipod function and as well an AUX input. The sound quality is CD quality and VERY GOOD.
if you are on a budget I'd take the cassette adapter. If you can spend a bit more the adapter is a better option since in the future if you get an iphone or an ipod you can plug it in and have the ability to control it from the car.
Old Jul 25, 2011 | 10:33 PM
Killabee44's Avatar
Csmeance,
Thanks a lot for your reply...
Yeah, I meant a 1/8" jack. The jack that is commonly used for aux out on car stereos.
I can spend but would like to keep the costs down. I've been looking at this one:
http://www.autotoys.com/x/product.php?productid=200
What do you think?
I have seen some of the ones you listed. Gonna check out the rest. $50 - $60 is about my budget.
Old Jul 26, 2011 | 12:06 AM
Killabee44's Avatar
I ended up ordering the isimple.. Will let you know how it turns out.
Old Aug 9, 2011 | 08:46 PM
Killabee44's Avatar
Installed the isimple. It was easier than I thought it would be. My only issue is that the volume on the auxiliary (the one I am using) is a little low.
Im trying to find a way to boost it.
Old Aug 9, 2011 | 09:03 PM
ttribe's Avatar
Is the volume all the way at max on your iPod/MP3 player when it's hooked into aux?
Old Aug 9, 2011 | 10:27 PM
Killabee44's Avatar
Yeah, I made sure of that. Don't get me wrong, it's not THAT low. It sounds like you have the volume up to maybe 40 or 50%. Still low though.
Is it possible to put in a more powerful amp on the stock stereo?
Old Aug 10, 2011 | 12:24 AM
geekybiker's Avatar
Look into a line driver. You can boost the signal into your HU.
Old Aug 10, 2011 | 02:13 PM
Killabee44's Avatar
Thanks, Ill check that out.
spudweb
May 22, 2016 02:39 PM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
polish_pat
Sep 25, 2015 12:24 PM
