[Full Guide] 9.7in Android Touch Navi Upgrade (Tesla Style) for Acura TL 2004-2008
Old Apr 2, 2022 | 07:36 AM
  #41
Jcollins32's Avatar
Originally Posted by OnlyDaanish
Sorry which harness are you referring to? All the cables needed come with the device.
I didn't receive the main harness that gives it power, I tried one out from walmart but wasn't the right fitment.
Old Apr 11, 2022 | 05:02 PM
  #42
OnlyDaanish's Avatar
where did u but it from? I would contact them for the cable. It should’ve been in the box
Old Apr 11, 2022 | 06:12 PM
  #43
Jcollins32's Avatar
I watched a vid on youtube and i was wrong, i did recieve the main power harness but not the harness for whats circled in red in the picture. Im not sure if that port is used though because the in the vid i watched the guy had his working fine without the use of it. The guy installing mine is an older guy, and cant get the deck to turn on. Im gonna try it myself. If i hook it up like the guy in the vid did and still no power, then im gonna assume its a faulty radio fuse in car.
Old Apr 14, 2022 | 04:38 PM
  #44
NetworkReject's Avatar
Has anybody figured out how to give permission to access a USB drive with 3rd party apps? It seems to be locked down and missing the app or settings page to do so.
Old Apr 14, 2022 | 07:10 PM
  #45
What issue are you having? Are you trying to install a 3P app? You should be able to plug in the usb to the Navi and it should show the contents inside the usb. I have tried it with box USB ports and it read my flash drive.
Old Apr 15, 2022 | 01:26 AM
  #46
Megglers's Avatar
Is there anyway to separate content within the main storage? I have music content i don't want my kids to access. It seems it just throws it all together. Also is there a way to disable the auto volume correction feature?
Is there anyway to change app colors? My car is all blacked out and then i have a light blue media screen. ;o
BTW
I have noticed a clock bug where the time is incorrect for a minute or two and then sets itself correctly. Also the upper display sometimes gets a little buggy, but is also quick to correct itself. I was worried about the needing a noise filter but my does not suffer from that issue. I got my unit in October.
Old Apr 15, 2022 | 08:59 AM
  #47
BTW
I don't think there is a way to separate the storage :/ and the clock bug is with everyone.
Also, i'm starting to think maybe old AMPs are causing the noise issue. Perhaps if I change my amp the noise will go away.
Old Apr 15, 2022 | 09:31 AM
  #48
Exclamation 04/15/2022 Noise Filter Update
Hi All! there is no way to edit the original post. @justnspace unless there is?
Anywho, there is an updated noise filter that from NaviTech that I hope to install when it arrives This is probably the filter the comes with the new devices!
Click here to buy the new noise filter
Old Apr 19, 2022 | 02:50 AM
  #49
Peng Mudan's Avatar
Tested both 9.7” & 12.1”
This is the guide on how to connect the noise filter
Old Apr 19, 2022 | 06:09 AM
  #50
huge thanks! I didn’t notice that I left the connection diagram out of my last post!
Old Apr 20, 2022 | 07:49 PM
  #51
Important software updates
Hi All,
I took some Time recently to reach out to NaviTech after ordering the new Noise Filter. I wanted to see if there was new software files and there are!! I will consolidated all the update files including the old ones in the new link to my Media-fire Share.
Why do I have the old update files?
Because I haven't tried the new update yet. I don't know what the update does and I don't really feel like testing it yet. Sometimes updates can screw up the device then there is no guarantee the old update files will fix it. But Im curious and I will try this weekend to do the update and return with the news.
IF your Navi is running fine, I would suggest skipping these updates or waiting for someone like me to try them first. The Navi Update probably won't add new features or anything and If your system isn't broken then don't touch it lol, just let it run.
Updates Link: https://www.mediafire.com/folder/0hf...%40onlydaanish)
Old Apr 21, 2022 | 11:26 AM
  #52
twokexlv6coupe's Avatar
This is a beautiful post. My entire OEM nav screen just crapped out on me last week and I have been mulling around the idea of the Tesla screen for a while, mostly for the Android Auto features. Sucks that it's not compatible with the OEM back up camera, but at least the license plate frame camera is pretty damn cheap. Can't win 'em all.
I thank you for the hard work you've put into this all inclusive thread!
Old May 6, 2022 | 08:57 PM
  #53
Haha thank you! You will NOT be Disappointed with the license plate camera! Fun fact, if you remove the entire license plate housing you can actually put the wiring for that camera behind your license plate and out through the top. It will give the camera a clean look as if its just a wireless camera frame. All wires hidden! no drilling required!
Old May 7, 2022 | 12:53 AM
  #54
Acura TL Builder's Avatar
Those Aluminum runners dont have to stick out. there is a little tab that needs to be shaved down on each side. Be careful not to ruin anything. I was able to get mine to fit just like OEM. Though I uninstalled it because I like the OEM look better. Also its too much needless tech for me.
Old May 13, 2022 | 11:10 AM
  #55
the part in red is 100% used on mine. However, Its connected with an adapter. The climate control goes into the adapter cable they gave and that goes into the navi unit,
Old May 13, 2022 | 11:12 AM
  #56
To each their own! I have been able to shave down the sides and get it to fit!
Old May 13, 2022 | 11:22 AM
  #57
[UPDATE]
I installed the new noise filter and it didn't do anything for me :/ I have a feeling the amp could be the issue. I have given up at this point on the hissing noise and will live with it like I have been. Some people have mentioned that they have no noise issue with the new model screens.
Old Jun 6, 2022 | 08:20 PM
  #58
Hi Everyone, I will be installing the 360 camera soon! I will make a separate guide to the 360 Camera. I wish there was a way to edit the original post
Old Jun 7, 2022 | 12:17 PM
  #59
Can't wait for the update.
Having had my old man's new CX-5 all last week while I was doing the clutch on the Type-S and using Android Auto with Waze got me thinking of some questions for this retrofit;
When using Waze (or whatever Nav app you want) does the nav sounds come through the OEM speakers? Or is there a tiny speaker on the tablet that it comes from?
And the notorious "wrong time" on the clock that has plagued everyone this year.... does this remedy that? (not exactly a deal-breaker, just curious)
Old Jun 7, 2022 | 12:19 PM
  #60
I’ve never had a Navi time issue. The Navi uses the speakers of the car minus center speaker.
Old Jun 9, 2022 | 06:53 PM
  #61
BOOSTED6IX-S's Avatar
If you ask nicely I think the mods can assist with that!
Old Jun 9, 2022 | 06:59 PM
  #62
@justnspace my good sir. I ask u once again. I have many updates for this post coming soon. Better photos and Organization. Is there a way to edit the original post 🥺
Old Jun 11, 2022 | 06:47 AM
  #63
o4Komodo's Avatar
Rev High; Drive Happy
Anyone use a custom launcher on the Tesla style?
Debating on it still but hate the stock UI it comes with.
Old Jun 11, 2022 | 09:08 AM
  #64
I did, and I hate them all. Although Car Launcher Pro is a good one with tons of potential which i might dabble in one day. Its only good though if you have another android tablet (Which I don't) and use it to create a customer layout. Then transfer the layout over to the Navi. If you try to make the custom layout on the Navi itself, its like impossible.
I can add to to my list of mods to make for the navi and one day i'll buy a tablet just for that.
Old Jun 11, 2022 | 12:13 PM
  #65
o4Komodo's Avatar
Yeah I use car launcher pro on my Volvo's android radio and loved it. But it didn't have the HVAC controls so it wasn't an issue with other launchers.
For the TL, did the other launchers end up hiding the HVAC? How would you dig through the settings to get back to it if so?
Old Jun 11, 2022 | 09:18 PM
  #66
Im pretty sure the HVAC stays at the bottom permanently. Even with a new launcher. I forget cause i deleted the app.. I also never ever use the HVAC from the display lol
Old Jun 12, 2022 | 06:03 PM
  #67
o4Komodo's Avatar
Yeah I only mention the HVAC thing 'cause I heard some people get a faulty unit where the physical buttons don't work and need a replacement (or they got shipped an old unit where the buttons don't work at all).
Hmn. Might take the bullet on it when there's a sale then. My radio has gone bad so I been meaning to replace it anyway. Was debating tablet mod or this. Only issue was finding a modern (and fast) tablet that's 8-9" is pretty damn hard these days.
Old Jun 12, 2022 | 08:06 PM
  #68
The unit uses your stock radio buttons. As long as you connect everything nice and properly it should be fine. Ive heard only one chase where someone’s climate control buttons didn’t work.
if your radio is out this is a no brainer tbh. I love it. You won’t regret getting it that’s for sure.
Old Jun 13, 2022 | 12:16 AM
  #69
o4Komodo's Avatar
Yeah my radio works but it's draining my battery so I left the fuse pulled for a year now lol
As mentioned so hard to find a fast modern 8-9" tablet. Only other option for something modern would be to do a CarPC. But the money I'd put into that I could probably just get this and have it plug and play. Less hassle. Wanted to do either of those since I actually still listen to CDs in my TL (and I still buy them whenever possible). I do have a random CD player at home I can listen to from there though.
Old Sep 8, 2022 | 01:47 PM
  #70
RxWorld's Avatar
For those that get this installed, how does it do in the cold? I live in Wisconsin and below 0 Fahrenheit days are not uncommon. Any thoughts on this?
Old Sep 8, 2022 | 01:48 PM
  #71
I've used this at lowest maybe 20F but I'd imagine its fine. It actually runs pretty hot on normal usage. Sometimes i'll touch the screen and it's pretty warm. I would doubt you'll have any issue below freezing.
Old Sep 8, 2022 | 06:21 PM
  #72
RxWorld's Avatar
Awesome. I see lots of sellers of this unit. Where is the best place to purchase in 2022?
Old Sep 24, 2022 | 01:53 PM
  #73
Locustjones's Avatar
Great post. Thank you.
I couldn't find details on RCA outputs but can see in the photo there are some red and white RCA lines. Do you know of there's separate RCA speaker front and rear and separate subwoofer (left and right or mono) RCA outputs?
I'm thinking of this but with aftermarket 5 channel amp and replacing all but the center channel speakers.
Old Sep 25, 2022 | 03:46 PM
  #74
Center channel doesn't work on this (fyi) . I do think there are separate audio inputs and they most likely work with your system but I don't know the specifics. But there is a Equalizer app with a ton of surround sound settings so I am sure you can plug in your system.
Old Sep 25, 2022 | 03:47 PM
  #75
NaviTech on AliExpress is still the best place.
Old Oct 4, 2022 | 06:16 PM
  #76
RxWorld's Avatar
I have the unit in hand and don’t see an input for an external microphone. Is it built into the unit somewhere?
Old Oct 6, 2022 | 02:52 PM
  #77
RxWorld's Avatar
Anyone have any issues with the steering wheel controls not working? I have 2008 and everything works on the unit but the vol and track change on the steering wheel. Is it a software thing I can change or what?
Old Oct 7, 2022 | 10:46 AM
  #78
RxWorld's Avatar
Figured it out. There is an app called "Control" and you have to configure it through there
  #79
RxWorld's Avatar
Found it, microphone is built in on the lower left of the unit
Old Oct 7, 2022 | 10:50 AM
  #80
RxWorld's Avatar
I'm having the same fitment issue. Where did you all trim on the silver bezel to get it to fit?
