Zaino question
Zaino question
Do I really need to use the ZFX Flash Cure Accelerator Additive before using Z-2 Show Car Polish for Clear Coated Car Finishes. I just bought the Z-2 and was going to use just that. Will that be fine?
I'm sure it looks great. You're supposed to use Z-1 with Z-2 if you don't use ZFX. ZFX allows you to put multiple layers of Z-2 on the same day. It quickens the drying process. Go to www.zainostore.com and there are many helpful tips there. Sal Zaino has some pretty strict recommendations.
Re: Zaino question
If you don't use the ZFX, you MUST use Z-1 FIRST as a primer for the paint, and every 6 months or so. If you don't Z-! before the first coat, the polish won't stick to the paint.
The ZFX serves as a primer as well as a curing accellerator.
just visited the http://www.zainostore.com/Merchant2/merchant.mvc link and looks like i'm gonna be another converted user. man...this stuff look great. look at some of the pics sent in by users....the finish on the g35 below is incredible and looks like glass.
I have a question....after I apply the multiple coats (dawn, clay bar, ZFX+Z2, ZFX+Z2, Z5). When I wash the car the next time, what detergent(?) can I use to wash with without affecting the beautiful shine or removing the zaino coats? Also how often show I reapply the zaino coats again?
Hmm, here's what I got from Zaino when I spoke to them...
New car process.
1. Wash it with Dawn.
2. Claybar it (using Z7 as a lubricant.)
3. Wash it with Z7.
4. Apply the Z2+ZFX, wait 30 minutes and buff off.
5. Shine car with Z6.
6. Repeat 4&5 up to three times.
When you wash your car, just wash it with Z7.
Apply one coat Z2+ZFX every couple of months.
New car process.
3. Wash it with Z7.
Originally posted by timnguyen9
just visited the [url]
Also, how many applications do you get with a set of these?
Has anybody used the Z-12 glass polish? It looks like it might be a good purchase for my older car.
Originally posted by Formula 350
Would not the last step be Z6 instead of Z5?
oops sorry, my bad, you're right
per site:
You can switch to Z-2 as soon as you are happy with the way the paint finish looks. Example, no more swirls, scratches etc. It's up to you. Z-2 has higher optical properties than Z-5. You can go from Z-2 to Z-5 and then back to Z-2 as often as you want. Z-2 and Z-5 are 100% compatible and interchangeable. You should always end with Z-2 as the last coat because of its higher optics.
Use Z-6 "Gloss Enhancer" spray as per directions, between each and every coat of Z-5 or Z-2. It really helps give a three dimensional look.
It's antistatic properties will reduce dust and dirt pickup by 60%. Z-6 can be used immediately after removing Z-2 or Z-5 or right before applying the next coat of Z-2 or Z-5. Most of my customers prefer to use Z-6 both, before and after Z-2 or Z-5 for that extra gloss boost.
Regular Maintenance
The number of coats of Z-2 or Z-5 is up to you. When you reach the level of enhancement you like, normal maintenence with Z-7 Car Wash and Z-6 "Gloss Enhancer" spray is all that's necessary. Naturally apply a coat of Z-2 or Z-5 whenever you feel it is required.
I'm no pro yet, but practice will make perfect!
per site:
Regular Maintenance
Do you do the full blown zaino process 2 times a year?
The rest of the times do you use the Z-7 show car wash?
I don't mind spending 6 hours twice a year to make the car look great and protect the paint. The rest of the time i want to wash and clean the car in 45 minutes. Unfortunately time is not on my side.....
acur8ly,
i'll zaino for those michelins you got swapped from the dealer. rosenthal?
acur8ly,
acur8ly
naaaah......you can keep them....maybe ACURA will give us all a nice xmas gift and replace with quality tires!
how are those tires? did you get a chance to do the cold 50mph test yet and what are the results? many inquiring minds on this forum want to know if indeeds it is the FIX?
acur8ly
acur8ly
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
