Yet another battery drain thread
Old 01-19-2019, 05:59 PM
alanfury75's Avatar
What's up everyone?!
Snow coming here to the NE and of course battery died last night. My 5 day out of state trip didn't help as my 08 sat in my driveway while I was gone.
I just bought this TL, battery looks new and I know about the possibility of HFL battery drain issue.
My question is:
If the HFL was disconnected, would the HFL instrument display still say booting up? Or would it say something else?
Wanted to ask before I do a tear down of the dome light area to try and disconnect.
Other question is:
If the HFL is disconnected, what other common culprits would cause a parasitic drain on our cars?
Last question:
I jump started her twice today. After the second time, the ABS and VSA dash lights stay on. Is that probably just a fuse issue or a sign of actual issues? I haven't scanned yet, but will after the storm.
Thanks in advance!
Old 01-19-2019, 06:22 PM
MyGuti's Avatar
If HFL is disconnected, it will still say Booting Up in your MID.
Old 01-20-2019, 08:38 AM
Turbonut's Avatar
Get the meter out and start pulling the fuses under the hood, then if it's the one that supplies power to the interior fuses, need to pull them. My problem:
https://acurazine.com/forums/3g-tl-p...solved-973316/
Old 01-21-2019, 02:04 PM
Coming to a city near you
Achance's Avatar
If you have a stuck cassette adapter in tape player it will drain battery. But you should be able to hear a small motor running even with car off.
Old 01-21-2019, 08:58 PM
alanfury75's Avatar
Thanks for clarifying, much appreciated!
Old 01-21-2019, 09:00 PM
alanfury75's Avatar
Thanks, hadn't thought of that. I have one in there now, though, not sure why since it already has a built in aux port. I used a cassette adapter in my 06 TL and never had an issue, but Something to consider though.
Old 01-22-2019, 12:02 PM
RAR
leedogg's Avatar
Received 1,286 Likes on 714 Posts
Hmmm. I removed the HFL above the dome light and havent had any issues since....
Old 01-22-2019, 12:30 PM
Yvuru's Avatar
It could be a battery on its way out. The HFL module definitely has to go. I've replaced mine myself and haven't had an issue since.
boiko
10-04-2012 08:55 AM
Hoopcanada
06-13-2012 12:47 PM
FullTilt
03-26-2008 06:33 AM
xasnxkiddox
11-21-2006 11:56 AM
shaolin
07-20-2003 11:28 PM
Quick Reply: Yet another battery drain thread
