WTF is Seafoam!?!?!?!?!?!?1
Old 05-05-2008, 07:30 PM
IlovemyAcura's Avatar
I've been seeing this alot what exactly does it do?
IlovemyAcura is offline
Old 05-05-2008, 07:36 PM
Registered VTEC junkie
jchcmax's Avatar
Basically an engine/fuel system cleaner for most engines.
http://www.seafoamsales.com/motorTuneUpTechGas.htm
jchcmax is offline
Old 05-05-2008, 07:38 PM
Oh i see
is it worth buying?
Old 05-05-2008, 07:43 PM
jchcmax's Avatar
Originally Posted by IlovemyAcura
Oh i see
is it worth buying?
It's your engine's best friend. Best maintenance cost that I know of! You need to stock up on it. If you go on Youtube, everyone is using it.
jchcmax is offline
Old 05-05-2008, 08:06 PM
I caught the mod flu
BLKURA's Avatar
Oh i see
is it worth buying?
I've been using seafoam for about 6 years and Love the stuff!!
BLKURA is offline
Old 05-05-2008, 08:14 PM
04DCTL's Avatar
haha, this sounds like rehab
"ive been hooked on this for 6 years, cant live without!"
and goldenboy don, that was not directed to you just so you know, just 6 years was an easy number
04DCTL is offline
Old 05-05-2008, 10:57 PM
paliknight's Avatar
how exactly do you use it for our TL's?
paliknight is offline
Old 05-05-2008, 11:21 PM
Lazy Idiot
blue.fired's Avatar
I think there are detailed threads for exactly this purpose.Use the Search
blue.fired is offline
Old 05-06-2008, 07:53 AM
06 WDP / 07 WDP Type-S
Be-in my TL's Avatar
I made a DIY a couple weeks ago... look for DIY-Seafoam
Be-in my TL is offline
Old 05-06-2008, 12:26 PM
'06 750Li Sapphire/Creme
ndabunka's Avatar
It's been used in the marine industry for YEARS but is MOSTLY related to winter conditioning of the engines (shutting down for the season or starting back up for the nex season). It basically removes carbon build up. IMHO using it on a car that you use everyday that is fairly new is a waste. These cars are ALREADY designed to be FAR more efficient than older cars. Now, if your car is three of four years old and you want to clean it out, run some through the gas tank as outlined in this forum....once (every two years or so).
ndabunka is offline
Old 05-06-2008, 12:32 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
All you have to do is remove the air intake snout to your TL
Look at the butterfly plate- its covered in crud. Now still think seafoam or some kind of cleaner is not needed??- then why do newer cars come with a port specifically to attach some sort of cleaning system!!
Anyone who understands engines knows they are huge crud factories of unburned gas and hydrocarbons- oil residue etc. That stuff gets right back in the intake and pistons, valves etc, and it clogs the engine oil passages too.
Anyone who says its just for storing engines has no idea of the many uses, in boats cars mowers- watercraft-jetskis and more...so probab;y not a current or ever user of the stuff!
The azinr threads have a lot of good info and practical experience from memebers on acuras of every model
01tl4tl is offline
Old 05-06-2008, 01:17 PM
ndabunka's Avatar
Anyone who says its just for storing engines has no idea of the many uses, in boats cars mowers- watercraft-jetskis and more...so probab;y not a current or ever user of the stuff! The azinr threads have a lot of good info and practical experience from members on Acuras of every model
I'm only a few years younger than you. I have a can in the garage. I've used it on boats for over 30 years. When I did my CAI on my TL 2 years ago, my butterfly was "pristine" so no point in using it at that point. But you do have me thinking that maybe I should look into it further on my 2004TL and see if I notice much of a difference.
ndabunka is offline
Old 05-06-2008, 01:48 PM
No He Can't
6MTUA5's Avatar
How come one of these threads pop up every few days? Do people not know how to read?
6MTUA5 is offline
Old 05-06-2008, 03:05 PM
erick3's Avatar
Oh i see
is it worth buying?
dude freaking 100%. stuff's the BEST...seriously; it solved my rough idling and improved my gas mileage like crazy! she's more responsive as well...NOTICEABLY
erick3 is offline
Old 05-06-2008, 03:27 PM
Jack ofall master of none
jonbwnnab22554's Avatar
I've used it on a few of my older vehicles. Works great. I don't see the big deal everyones making. If you wanna use it go ahead, if not then don't.
jonbwnnab22554 is offline
Old 05-06-2008, 04:00 PM
01tl4tl's Avatar
It makes a big differance if you have over 50k miles- that for sure
Will it help overall at 15k on a new car- not as much, but prevention is the key to
better mileage and healthier engines.
There are other products that do similar things- if one of us buys the 50 honda kit- that may be the new rage- but for now,,,,
after looking inside the Edelbrock intake of my truck- and my 01TL TB plate, I decided it was worth doing. Both appreciated it, and a spray of the TB plate now and then helps.
Great pic on another thread of TB crud buildup- the cranckacase breather tube goes direct to the intake port!
01tl4tl is offline
Old 05-06-2008, 04:11 PM
ggesq's Avatar
Received 2,182 Likes on 1,210 Posts
Your absolutely right. There are way too many threads on this topic and if the OP or anyone for that matter needs further clarification, I think a search is in order.
ggesq is offline
acuratl26
04-23-2020 07:30 PM
Rapture
10-04-2015 12:05 AM
E92Vancouver
3G MDX (2014-2020)
09-21-2015 02:32 PM
IlliniAcura
09-19-2015 09:31 PM
ahsm
09-09-2015 08:35 AM
Quick Reply: WTF is Seafoam!?!?!?!?!?!?1
