Windshield washer spray shoots too HIGH.
For the first time I used the windshield washer spray and noticed that
there was lots of water on the roof and the rear window of my car. I
thought that I could simply bend the spray nozzle and fix the problem,
but it can not be done. Spray nozzles are housed in casing and can not be
bend and/or redirected.
Any ideas about what can be done about this?
you can adjust the nozzles and have it spray lower but when you drive it won't spray high enough. i think the reason is because the nozzles are located closer and somewhat lower to the windshield that acura had to make it aim higher in order to be able to hit the windshield when the car is moving. the traditional nozzles are further out on the hood and a little higher up therefor the spray is more direct.
2004 TL Washer Nozzles Are Adjustable
I also noticed that my washer nozzles were firing too high on the driver's side of my TL. While the nozzles ARE adjustable, I was unable to do so such that they fired into the center of the windshield. I found that it was all too easy to have them fire into the wiper arm itself. I have now returned their setting to the top of the windshield. My 2000 did not have adjustable washer jets, but they were properly aimed at the factory.
Originally Posted by Zed's TL
I also noticed that my washer nozzles were firing too high on the driver's side of my TL. While the nozzles ARE adjustable, I was unable to do so such that they fired into the center of the windshield. .
Originally Posted by screaming
That's illegal in some towns... Just make sure you're 21!
-Steve
-Steve
Waaay past 21... in fact, I'll be counting backwards this year!
this is really annoying because what ends up happening is the mist goes all over your roof/rear/sides and leave water spots...happened to me today after i washed it
Originally Posted by xlilbluux
leave it high, spray it when u have tailgaters. it works on the freeway and its funny.
Slacker
i used them the other day and accidentally sprayed some older ladies in their convertible 3 series behind me, i saw them in my rearview and they were pissed (i laughed)
MrHeeltoe
20
02-23-2023 01:54 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
