Window Cleaning
Window Cleaning
I don't know about anybody else, but I have major problems cleaning my front and rear windows! What is the best method that cleans the window and doesn't leave it streaked? Inside and out.......
http://www.acura-tl.com/forums/showthread.php?t=76508
The main thing about cleaning windows is what you use to clean with (towel, paper, etc.) than the cleaner itself. The best thing I have found to clean windows without streaking is a micro-fiber towel, make sure its a good quality instead of a cheap one. You can just use it dampened with a little water, distilled is suppose to be best. Mostly I use a window cleaner called Finish-First, it can be ordered online. It's the best cleaner I have used, to me it's a lot better than Stoners and others... Some people say newspaper is good also. To me it tends to leave those fine hair-like fibers though. ... I also sometimes before cleaning the windows go over all the glass with a glass polish to remove any water-spots, etc. to make the final cleaning look spotless. I use a glass-polish made by company called Duragloss, it's in some car part stores and they have a website also. I don't try to use it on the side mirrors, think they are sometimes made using a plastic material.
....Hope this helps, I know my window cleaning is a lot easier using this method.
xsilverhawkx
09-28-2015 06:51 PM
