Will Type-S headlights fit on 04 front bumper?
The "Parts & Modifications" in "Performance Parts & Modifications"
The intention of this forum is to discuss performance oriented issues and topics, and the parts and modifications which affect said performance. This means only performance parts and performance enhancing modifications should be posted in this forum.
It was never intended to be a receptacle for all parts and all modifications.
If you want to know the part number for a door handle, or you need to find some information on a part, or you want to discuss the various parts of the a-spec body kits, or you want to ask a question about tint, or you are interested in carbon fiber engine shrouds, or any of the many other threads that have been started here when they shouldn't have been, please post your thread in one of the other appropriate subforums or the main forum.
If your modification is not performance oriented, which includes but is not limited to tint, cleared headlights, rockblocker on lights, new shift knob, etc., none of which affect the performance of the vehicle, also please post in one of the other appropriate subforums or the main forum.
The TL-S headlights will require you to buy slim ballasts from the 2006+ TL and as well new turn signals sockets. Cut off the old ones and wire in the new ones is the way to do as I've seen on here.
HOWEVER, I must warn you that you risk melting the DRL shroud on the TL-S lights as they were designed in mind with 9005 bulbs as DRL's and not the 9006 bulbs at full power like are in the 2004-2006 TL as Fog Lights.
06 WDP/Ebony MT NAV ASPEC
It is because the TL-s lights were designed to only use a drl in that location, when using a bulb at full power,too much heat is generated and it may melt the shroud. Besides that the optics in the headlight are not designed with a fog light in mind.
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
robowarrio
09-01-2015 09:25 PM
