Will this oil filter fit?
Old 02-23-2014, 08:05 PM
dyang17's Avatar
Hi guys will this oil filter- Bosch Distance Plus 3312 fit my 2005 Acura TL base. I know this filter is bigger then the recommended stock filter. Thanks!
Old 02-23-2014, 08:20 PM
coffeebowl's Avatar
so this wasn't listed for the tl by the oil filter guide book? if its not recommended by the guide then I wouldn't get it. I use Fram high mileage, I have no problems it it. of course though I have high mileage. But sorry I don't know if it would fit but I wouldn't bother with it, that's just men.
Old 02-23-2014, 08:43 PM
anx1300c's Avatar
Originally Posted by coffeebowl
so this wasn't listed for the tl by the oil filter guide book? if its not recommended by the guide then I wouldn't get it. I use frame high mileage, I have no problems it it. of course though I have high mileage. But sorry I don't know if it would fit but I wouldn't bother with it, that's just men.
If you care about your car, you should stop using Fram filters.
The following 4 users liked this post by anx1300c:
Acura-OC (09-08-2014), DMZ (02-24-2014), GKinColo08TL (02-25-2014), thoiboi (02-25-2014)
Old 02-23-2014, 09:19 PM
coffeebowl's Avatar
Really? Just curious into why. What do you recommend?
Old 02-23-2014, 10:10 PM
thisaznboi88's Avatar
Old 02-23-2014, 10:15 PM
main70072's Avatar
Purolator and Wix makes good filters.
Old 02-24-2014, 12:08 PM
dyang17's Avatar
Is there anyone out there that can just tell me if this fit? Mostly i think it does fit but just want to make sure. I know this is the same size s2000 filter as well and most people on here run it.
Old 02-24-2014, 01:05 PM
Received 16,263 Likes on 11,973 Posts
all hondas have the same filter thread pitch.
yes it will fit
nttstt444 (02-27-2014)
Old 02-24-2014, 01:34 PM
bp_spets's Avatar
If its the same size as the S2000 filter, then it should fit.
Old 02-24-2014, 02:03 PM
flyromeo3's Avatar
According to Bosch site, the recommended filter is
D3323 - Oil Filter
The D3323 and the D3312 share the same connection size being M20x1.5
this filter fits 2010 Hyundi accet
Its diameter is bigger than the 3323 and shorter height.
Old 02-24-2014, 05:12 PM
Turbonut's Avatar
It will fit:
3312/Acura
Gasket ID 2.13" compared to 2.22"
Gasket OD 2.42"/2.48"
Gasket thickness .2"/.28"
Height 3.08"/3.47"
OD 3.02"/2.69"
Thread 20mm x 1.5mm
Relief Valve PSI 9-15/13
As they say the S2000 will fit, the 3312 is a direct replacement, at least according to the catalog, so no problem.
dyang17 (02-27-2014)
Old 02-24-2014, 05:21 PM
DMZ
Head a da Family
DMZ's Avatar
The 3312 is for the 2G TL and fits the 3G TL perfectly. In fact, I'd rather use it because it's bigger, and I do!
Wix for example only makes 1 filter for 2G and 3G TL's. They can fit the same threads.
Old 02-24-2014, 08:20 PM
cruc1a7's Avatar
I just bought my TL recently and did a oil change. I got a surplus of s2k (PCX) filters laying around. Comparison of how big it is compared to what was on there when I got it:
Old 02-25-2014, 09:56 PM
2017 TLX TECH V6
eaglegreen48's Avatar
Wix or Napa Gold. Can't go wrong.
DMZ (09-09-2014)
Old 02-25-2014, 10:09 PM
ej1serge's Avatar
I always use hamp cuz I bought a box of them a couple years ago, wix is what I'll be using once these run out
Old 09-08-2014, 07:40 PM
asb32952's Avatar
this one fits a s2000 b/c of the mounting position.
http://www.bobistheoilguy.com/forums...Number=2440239
here are the dimensions:
http://www.zoro.com/i/G2157775/?cate...ontent=general
will this fit my 3.2 cl-s? or what would be the biggest baldwin filter that fits?
mada51589
05-03-2022 08:54 PM
bungln
02-20-2019 08:47 PM
ghuns
09-16-2015 04:26 PM
HydrasunGQ
09-14-2015 10:14 PM
datadr
09-12-2015 09:12 PM
Quick Reply: Will this oil filter fit?
