Will front of car support a jack?
On my 96 Accord, I had a mounting point for a jack in the center about a foot behind the front bumper. I used this to lift the front of the car and put my jack stands on the sides just behind the front wheels.
Is there any point on the front of the TL where I can jack from?
I need to get the front of the car off the ground so I can get my jack stands under the side points, but can't find a sturdy place to jack from...
Stay Out Of the Left Lane
Originally Posted by djlandkpl
The TL has a jack point in the center. I think it's detailed in the manual.
I noticed you are from Norton, MA as am I!! What are the odds of having two TLs in a small town like Norton and have them both be members of this site??
This brings up a question of which I would like comments. When you take a car in for tire replacements, they nearly always place the four floor jack lift supports under the car instead of using the jack points shown in our manuals along the sides of the car. When would you instruct them to place their lift supports?
Originally Posted by Road Rage
There is the same thing on the TL as the Accord - it is under the front crossmember. And yes of course, it can easily support the car. It is covered in the manual.
Hmmm...I checked it out when I first got the car and never saw it.
I shoulda RTFM...I'll check it out when I get home. Thanks!
Yes, I've seen the jack and lift points in my Service Manual. But have you ever noticed that when you take your car in for new tires, the person doing the work positions the floor lift under other areas under your car.. like suspension components or parts of the subframe?
The manual's 6 jack points are the ONLY places where your car should be safely jacked.
i have seen them lift like that before, normally its some young kid that doesnt know any better. the four arms of the lift are swung under the car at like 45 degree angles and then they just raise it up.... i have stopped them from lifting my contour before like that, have never had to have the tl lifted as of yet (in a shop at least).....
Originally Posted by Lore
No, I've never seen that. They always lift the car using the 4 jack points on the side of the car.
You never know... My G35 has the same jacking points all around as my wife's TL. But everyone (including the dealer) swears up and down, that you can lift/hold the car using the frame rails, which are located about 4 inches inside of the side jack points, and up about 2 inches. I'm pretty sure the TL has the same frame rails... If you've ever seen a picture of a car frame without a body on it, the beam that runs along the sides, is the frame rail.
That being said, I think the side jack points are pretty universal. Everytime I go to the tire shop, I like watching them work on the cars. I usually see them always looking under the car, and adjusting the location of the lift beam, sometimes putting on a padded adapter.
Oakes
Wash & Wax
Oct 12, 2015 11:17 AM
Mugen TSX
Eastern Canada
Sep 1, 2015 11:11 PM
