Wideband gauge ??
Old Mar 25, 2016 | 12:11 AM
ArtPerez805's Avatar
Wideband gauge ??
I'm sure they're is a thread about this
But I'm gonna try and install a wideband/lamda gauge.
I've never done any wiring or install like thiss...so if anyone can post a thread or their diy for me thanks👌
Old Mar 26, 2016 | 05:22 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
It's just a key on + ,a ground ,and install the sensor before the cat.
Old Mar 26, 2016 | 05:32 PM
So would that be before each pre cat?
Or at my test pipe?
Ok would that be b4 each pre cat or at my test pip
Old Apr 1, 2016 | 05:06 PM
EvilVirus's Avatar
Wrong section to ask this in. You would get more responses if it was in the performance section. Ask Mods to move it
Old Apr 12, 2016 | 11:03 PM
Duronn's Avatar
That depends if you have pre-cat deletes or not. On mine, I installed the bung and the sensor of the J-pipe, but I have free flowing pre-cat deletes. If you don't, you wanna install it before the pre-cat...hmmm...but I'm not sure where.
Old Apr 15, 2016 | 03:40 AM
Would i be able to take out one the existing o2z and use the wideband o2?
Old Apr 15, 2016 | 11:48 PM
Duronn's Avatar
I have no clue, I dunno if its the same size but you need the O2 sensors. Why do you need a wide band?
Old Apr 16, 2016 | 02:02 AM
To see how its gonna be running while on nitrous ..want to monitor it
Old Apr 16, 2016 | 04:51 AM
Duronn's Avatar
Well according to the AEM wideband instructions, you're gonna have to mount it before the precat: "For accurate readings, the sensor must be mounted before catalytic converters and/or auxiliary air pumps." If you don't have pre-cat deletes, you may wanna ask a muffler shop if they can make a hole & weld close to the O2 sensor since thats the only reasonable place.
Old Apr 16, 2016 | 07:32 PM
I that's what im going to have to do,I'm they can
