When VSA off do the car loose power
VEHICLE STABILITY ASSIST™ (VSA®)
The TL is equipped with 4-channel Vehicle Stability Assist™ (VSA®) that helps the driver retain control of the car in the event the vehicle reaches its dynamic traction limits. For example, this may occur through aggressive cornering, encountering ice or dirt on the road, or entering a decreasing-radius corner too fast.
In the event of understeer, the system can apply the inside front and rear brakes to increase yaw, slowing the vehicle and enabling it to complete the turn. Engine torque may also be reduced by coordination of the Drive-by-Wire Throttle System™ and powertrain control module.
The 4-channel system controls all four brakes independently. In the event of oversteer (where the rear tires lose grip), the system can apply the outside front and rear brakes to decrease yaw, slowing the vehicle and enabling it to stay on its intended path.
An indicator light on the instrument panel alerts the driver whenever the VSA system is actively enhancing the vehicle's stability.
The traction control component of VSA uses sensors that monitor each of the wheels and a computer-controlled modulation of engine power and front brakes to help prevent wheel spin when starting out or accelerating. If the sensors detect wheel spin, traction control reduces engine power and applies brake force to the affected wheels. This helps the TL maintain traction during acceleration and helps the driver retain steering control, even when accelerating on slippery surfaces.
A cockpit switch is provided to disable the vehicle stability and traction control aspects of the system while leaving the ABS system fully functional.
from Hondanews.com
from Hondanews.com
