When I go full throttle does the A/C dis-engage?
Brother Sum
I heard some cars will dis-engage the a/c compressor to poll more power from the motor when you go full throttle. Does that happen in our TL's?
Thanks in advance.
-J-Tow
Thanks in advance.
-J-Tow
2004 SSM/EB/5AT/Navi/RSB
I think most cars made in the last 10-15 years do this. On some (I don't know about the TL), the compressor clutch is tied to the vacuum system. Lots of vacuum disengages the compressor.
Grandpa
A supercharger will put boost in the vac system at WOT. If vac disengages the compressor, then the compressor is engaged under boost. More WHP should be found in supercharged cars by using the TPS to trigger the compressor clutch.
Someone please confirm how the compressor clutch is triggered
Originally Posted by TLOBLLC
Whoa!!!!
I didn't mean to imply this is how it works on all cars.
From the service manual, page 21-59:
NOTE: It is normal for the compressor to turn off under certain conditions, such as low idle, high engine coolant temperature, or hard acceleration.
I looked for a while but couldn't find anything about how this works or what turns off the compressor.
WDP Director of R & D
The clutch itself is operated electrically. Whether or not the electric signal to the clutch is sent via a "vacuum sensor" or from the computer I don't know. As mentioned, I would also surmise it's computer related in todays vehicles.
Now, as for a "vacuum sensor" activated setup, I would have to say it is disengaged due to "low" vacuum rather than a high vacuum situation. At wide open throttle you get a serious drop in vacuum. At an idle and normal driving is were engine vacuum is the highest.
A supercharged engine on the other hand would/could change the whole vacuum discussion......
Either way, if one was really concerned about this you could always install your own WOT switch/relay to kill the compressor and/or alternator etc. if desired...
Originally Posted by quake97
If the TL does this, it's a nice feature. I remember the gold old days with my '86 Buick Century when you absolutely couldn't pull out in front of someone with the A/C on.
Joe
Joe
-Brian
Wild Child
Well just to let you in on a little something. after 6500 rpm, the compressor shuts off so that it wont explode. That's what's up. Its not to give you more power. Its a "dummy proofing" feature to keep idiots from blowing up compressors just to show off a little speed. I know I just turn off the compressor before lift off. It's common since. If you know you wanna punch it, why niot turn off the compressor?
Powered by Guinness
This is a pretty simple feature that's probably been around for as long as air conditioning in cars. I've worked on some pretty old carbureted cars that had AC cutout switches activated by the carb linkage at WOT. On computer-controlled cars, it's pretty simple to have the AC relay controlled by the computer with throttle position one of the inputs. I'd be surprised if any car made in the last two decades didn't have this (WOT AC cutout).
Powered by Guinness
Wild Child
Originally Posted by Aegir
Where did you learn this from? This response implies access to some detailed TL knowledge. Whatever your source was it sounds like it could be a good reference to obtain.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
