When do you change your ATF fluid
Hi I was just curious what everybody's intervals are because i finished my 3x3 10000miles ago was thinking on changing it every 25000?
So roughly every 2-3 oil changes.
Undying Dreams (11-03-2012)
BANNED
i do it every other oil change, a 1x3...so roughly every 15k miles or so.
not taking any chances with these glass transmissions. the $30 is worth it for piece of mind.
Florida Wen (11-04-2023)
Assuming you are starting off with clean fluid, every 15K is about right for a drain and fill. It's way better doing frequent partial fluid exchanges over less frequent exchanges of all the fluid. If you notice a difference in the way the transmission acts after a drain and fill, you're not doing it frequently enough or just crazy.
Do it each time you drive it.
Home Of The Gemini Method
I'm sitting on about 40,000 miles on the Redline D4 and it still shifts like the day I did the 3X3.
I am however going to replace the switches and do another 3X3 in the next 3000 miles. The car is now over 106,000 miles and needs the maintenance.
I go every 20K ish or 3 oil changes. I do the ATF after I change the engine oil since the car is on ramps and the same drain pan is out. I'll be doing the ATF next oil change at around 58k miles. I'll be interested in checking the magnet this next time since I had Redline Type-F in the system for 20k miles- hopefully I'll see less wear. I took pictures the last change with a paper towel smear of the wear to compare against this next time.
Nothing wrong with changing more frequent- just not sure if it really will help if you're also not changing those sensors.
Received 3,824 Likes
nanos
11-12-2015 08:41 PM
HydrasunGQ
09-14-2015 10:14 PM
