wheel lock on 05' tl problem
CARBON FIBER WDP TL
i just changed one of my tires for a couple of days and unfortanetly i stripped my wheel lock and the lug nut... im going to have to change all the tires in a couple of days what should i do...i dont want to buy a new set if i dont have to..if i can buy a new wheel lock and just a new lug nut that be great...has anyone ran into this problem
Last edited by poormans_tl69; 09-08-2009 at 05:36 PM. Reason: didnt add "problem" in the title
Mistuh DRiiVA
yeah one of my lugs were stripped and i ended up puttin to much pressure on it and broke the bolt right off. That was a PITA to get fixed by my dealership, luckily was able to get it replaced under waranty as well as the bolts. I would take it to acura if youre still under waranty and see what they can do for you.
That happen to me too but what i did was i took my car to a shop near my house and they put more pressure to the impact gone and problem fix...the only thing you can be able to used that wheel lock anymore you have to put the regular nuts on it with out wheel locks...i hope this helps...good luck...
CARBON FIBER WDP TL
yea thanks guys...what i think im gonna do is take the all the locks off and get new ones...as long as i take the one i stripped i think i will be ok.. im gonna try at work tom and check it out
mada51589
05-03-2022 08:54 PM
tman570
06-11-2019 07:56 AM
ahsm
09-09-2015 08:35 AM
braveheart
09-07-2015 08:12 AM
