What's the secret in removing the plug of the oxygen sensor?
Old May 9, 2022 | 05:45 PM
sujitroy's Avatar
I got a new O2 oxygen sensor for bank1 sensor 1. For the life of me I could not separate the connector/ plug. I pressed in the hold down clamp but I could not shift it. As a test, I'd thought I'd try separating the plug from bank 2 sensor 1 but couldn't do that either.
The car has covered 283k miles. Is there a secret to removing the connector.
For back 1 sensor 1, I remove the bar across the engine to get to it. but no joy.
Roy
Old May 9, 2022 | 06:04 PM
Acura TL Builder's Avatar
Hold the tab down and twist the two apart with a flathead screwdriver.
Old May 10, 2022 | 09:40 AM
sujitroy's Avatar
I tried with a screw driver, but was able to twist. Thee one at the back it very difficult to get to
Old May 10, 2022 | 10:03 AM
Legend2TL's Avatar
AZ Community Team
Do not twist it, it is not a twisting connector only a push/pull connector with a locking lift tab. Try spraying some 100% silicon spray on the connector shell, then press the lift tab and gently rock the connector shell back and forth. The connector "O" ring often causes the connector to stick.
Old May 10, 2022 | 10:31 AM
I ment to put the screw driver and twist in the gap between the two plugs. this was the twisting action will seperate the two.
emry
Jul 2, 2021 07:43 PM
TheSauceBoss
Feb 28, 2020 07:43 AM
80stang
Nov 21, 2018 09:13 AM
LazLong
Jun 16, 2015 01:32 PM
1789
Sep 29, 2009 08:40 AM
