whats the flange size?
Team NightHawk VP
anyone know what size flange it is for the third cat. im planning on replacing it with a test pipe, but i need to know what size the piping is, and the distance from 1 hole to another.
its a triangular flange and if anyone knows the size, please post them
Cliff
Cliff
Is there a gasket there? If there is, you could check it at the dealer. Have the gasket in hand and check the bolt pattern and the inner diameter. It could be of help.
One on the right for me
While the TL might have enough resonators and mufflers to help keep the noise down, removing a cat often makes the car sound especially bad. I dont think it will be noticeable because there is so much sound reduciton in the exhaust system but it does change the sound, and usually not for the better...
ExcelerateRep
10-14-2015 08:20 AM
AcuraKidd
09-25-2015 11:18 PM
