What type of motor mounts
I am needing to change my motor mounts and wanted to know if anyone has had luck with aftermarket mounts? I have about 145k miles and don’t want to spend too much money on new mounts but I also don’t want to change mounts and have too much vibration/rattle.
Latent car nut
Automatic or manual? For the Automatic models it is open for debate as to whether some of the better aftermarket mount kits/sets (five mounts) will work as well and last as long as the OEM mounts; for the 6MT models, I was not able to find even a single company which made all six engine/transmission mounts; I ended up buying OEM.
justnspace (09-17-2018)
it really depends on YOU.
How much you want to spend and if you want to go racecar...
if you really want an OEM like ride, go OEM.
perhaps you could save a little bit of money on a OEM-like aftermarket, like the ones found on www.rockauto.com
or perhaps you want to go FULL race car and pick up a harder type mount..
it all depends on you and your budget.
Latent car nut
All Around Klown
Be sure you get the mounts WITH the vacuum connection (dont remember if 1 or 2 have that). The mounts without will transfer a lot of motor vibration throughout the car.
boxmanryan
01-12-2015 09:15 AM
NighthawkBlue
10-24-2012 02:39 AM
luxerymobile
03-29-2011 12:48 PM
asiankidd
12-27-2006 06:32 PM
