What should I do? Only need front pads...?
(Posted this originally in the Problems section) Hoping to get some better feedback here.
So as the header states, I'm on original rotors, less than 50k miles, only need front pads. Rears are good per inspection.
Should I just get:
1. new pads, resurface rotors
2. new aftermarket drilled rotors (ex. BrakeMotive,etc), pads for just the front (problem don't match rear)
3. replace all rotors, pads (more expense than really necessary)
Thanks for your feedback.
Should I just get:
Personally if the rotors aren't warped, I would just replace the pads and call it a day. 15 minutes, $50-70 and you're back in business!
That is unless you really are wanting to modify...but personally I would only modify as the parts wore out. (i.e. pads now, rotors later, and eventually the same in the back).
Some better feedback? Your two threads are little over an hour apart, give it some time. You got advice in your other thread and you just got the same advice in this thread as I gave in the other.
BoricuaTL
Apr 8, 2016 01:08 PM
sputik
Sep 7, 2015 01:40 PM
