what is that round cutout hole in the front bumper?
CEO, Team Anthracite
Behind it is a ring which you can use to tow your car in case it's stuck. It's in the manual and describes the proper angle the towing car should pull your TL out.
It is used in the event the car needs to be towed or winched out of a ditch, etc.. There is a screw-in winch attachment in your trunk that is essentially a large eye-bolt that screws into the hole located behind the cutout. Then, you can attach a winch to pull the car, etc.
TL hacker
I didn't notice but does it have any of those tow hooks under the front bumper? My old '93 del sol have 2 of them, one in each corner. Is this tow hook meant to replace that?
Moderator Alumnus
Basically, I don't know how strong it is, it seems to bind with the bumper, not the frame. The bumper is removable, so I wonder our car can be safely towed?
Anyone knows how strong our bumper is connected to the frame?
Thanks.
TL hacker
Yes, I know that. But my question was whether this tow hook that goes into the front bumper is meant to replace the 2 under bumper hooks (one in each corner) like on my old car. Or does the TL also have those hooks under the front bumper in each corner. I'll go check my TL in a few minutes.
Also, my old del sol also had an under bumper hook at the rear in the middle. I wonder if the TL also has that. After all, if you end up in a ditch you may need to be pulled out backwards.
TL hacker
Originally posted by jackal2001
Hey are you the same Zeuser that does DCX???
If so, get back to work!!!
Ha Ha
Ha Ha
Team Anthracite Rocky Mnt
There are no hooks under the car. The dealer told me that this system is used as the old hooks under the car have a tendency to damage the plastic on the bumper. (When the cable is pulled and the angle is to great it rips the bumper)
Oakes
Wash & Wax
10-12-2015 11:17 AM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
robowarrio
09-01-2015 09:25 PM
