View Poll Results: What Gas Brand Do You Use?
Voters: 201. You may not vote on this poll
What Gas Brand do you use?
BP, Shell, and Chevron. When i was going to get an s2000 (before I realized I just cant fit), they were having this big thing about how some gas really is better than others for performance. I didnt believe them at first and I suppose it could just be that placebo effect, but I feel like it does make a difference. They had a list on s2ki.com that included a few other top tier gasses than the ones I use, but those are the ones in my area. I put Citco, Amaco, and old school Exxon in the "boring" cars though.
Originally Posted by datmrman
Costco, cause its cheap and its near by.
Sometimes, Chevron because I can feel the difference in the drive compared to Costco gas.
Dragging knees in
Sunoco because I can get 94 if I felt like it, and it's the official fuel of NASCAR.
Or I get Shell just as often... I always ran Mobile then one day I was on the highway and was dangerously running low on gas. I found a Shell station and filled up on the 93 octane V-Power. I honestly didn't even give it a second thought, but I realized all of a sudden that my car felt more responsive and smoother.
I could only vote for one in the poll, so I picked Sunoco because I get Sunoco a little more often than Shell.
Branded gave me better mileage
I run Exxon Supreme or Shell V-power, mostly because they are in my daily drive path. I would run Chevron because of brand loyalty, but they've all but pulled out of the Nashville area.
When I switched from Swifty(cheap) to the major brands, my MPG went up by about 3 miles per....I was very suprised.
-jr.
-jr.
One on the right for me
I've had good and bad tanks at nearly every station I've filled up at, regardless of the brand, so I'm not very picky. usually its whatever is the least expensive. Usually Arco, 76, Chevron, Shell...76 is close to where I live so if I'm in a hurry I just fill up there. I hate Arco cause I usually never have enough cash for a complete fill up and the .45 cent ATM fee sometimes isnt worth what I save if its only a few gallons.
2016 E350 Sport
Oh no.....not another better gasoline thread! My father worked at an oil refinery for over 20 years. If you only knew how similar all the brands are you will stop wasting your money on Brand X with Y additive. Since he worked at a private oil company they made gasoline for ALL of the major oil companies. They did not shut down gas production for each oil company to avoid contamination wiht someone elses gas. Think about it! All the oil companies try to get you to believe their gas is better because is has such and such additive and they care about the environment. Gasoline is highly regulated and must satisfy certain specifications. Remember, your car has to run using any oil manufacturer you choose not just the one you think is better.
Dragging knees in
Well, the way i see it is that if the difference in gas prices is 7 cents (which is usually the difference in my area between citgo and shell which are the exact same in distance from my house)... if it takes 14 gallons til fill ' er up. Thats .07 x 14 which is equal to .98 cents. If it costs me 98 cents to trick myself into thinking that my car is faster...in my book, its worth it
Dragging knees in
Originally Posted by g0tb00st
you guys use premium in your car??? 89 works for me...the TL's engine isn't forced inducted or anything that would require you guys to run 91+ oct.
Second post on the page --> https://acurazine.com/forums/showthr...=129452&page=2
And this thread isn't about octane rating... only about brand(s) of choice.
Keep Right Except to Pass
The poll choices don't include my choice—whichever major brand is most convenient when I need gas. Typically I will use one of three: the Shell that I pass on the way to work, the Mobil station in the next county over some 10 miles away that has a car wash with no rails (good during the winter, and 22¢ a gallon cheaper than in my county), or the Hess station in Alexandria that's 20¢ a gallon cheaper than the Exxon located right across the street from the Hess!
I never use the Liberty station located about 2 miles from home, though, even though it's cheap. I don't know anything about Liberty gas and therefore I don't trust it.
2014 RDX Tech AWD
Hess
Hess is generally the cheapest and closest in proximity to my house (although there are probably 20 gas stations in a 5 miles radius, Hess always seems to just "be there").
Only use 93.....
Only use 93.....
Fightin' Texas Aggie
HEB. There are 3 stations at the same intersection. The majority of the time they are at the same price, but if one is going to be cheaper then HEB usually is. Plus it's the easiest to get in and out of given the way I am normally going.
not vtech... VTEC!!!
My car had nothing but Chevron from the station near my house for 2 reasons - 1. It's a Chevron station, 2. One of the cheapest in the area according to gasbuddies.
I try to use shell v power but if one is not in range then I go with BP, then Mobile. I most likly use those gases more then others because they advertise them on T.V. more, so they are in my brain.
Is there really a big differece in 91 octane Shell and 94 octane Sunoco?
well at one point chevron had lil banners saying...there were rated top tier by some well known people (i forget) and that the gas they provided (Supreme Chvron with Techron) was made specifially for BMW and HONDA motors...How much of this is true I dont know...but it made me want it more!!! they even had pictures of pistons on there showing one with alot of carbon built up and all that comparison shit....
Oderint dum metuant.
I usually get the cheapest, and that's from one of two stations, both Petro Express (one near work, one near the house). If I run low on gas and I'm not near either home or work, I get whatever is available (always 93 around here...very few places have 91).
I'm a Chevron junkie. I CAN'T GET ENOUGH!!
Also, if I don't think I can make it to a Chevron before I run out of gas, I will put in like 5 dollars of some other gas brand, and then fill up at Chevron ASAP.
Team Anthracite Member
Exxon/Mobil (93)
Why? Cause the guy up the street at Shell is priced out of his mind - oh and he is a total idiot too. Plus UPROMISE $$ when I use Exxon or Mobil...1 million tankfuls more and my boy is going to College!
RAR
One thing I learned in this thread is that Chevron might actually be quality stuff, always thought it was one of the lower quality brands...(probably because their prices were so cheap)
Here's a money saving tip, Discover has a gasoline card - save 5% off any gas station, and 1% off anything else. If you already have a discover, switch it to the gas card.
2016 E350 Sport
Originally Posted by Laxplaya11385
so are you saying that any gas station that has 91-93 octane would work jsut as well in our car? (Shell vs. Raceway or another lesser name)
RAR
Originally Posted by levon1830
But is there an annual fee on this gas card? If so, that's going to eat into your savings. Assuming you drive 15,000 miles per and your average gas mileage is 22 mpg (that's what I average), that means you consume ~682 gallons of gas per year. 682 gallons x $2.50/gallon = $1705 in gas per year. $1705 x 5% = $85.25 in savings per year. Just something to think about.
https://www.discovercard.com/apply/gas/
No annual fee, its the same as the average discover card except you also get 5% back on gas in addition to 1% back on everything else.
