What does this wire go to???
BANNED
everything is fine no lights on im confused... and to order online i need new front end harness which is expensive..... i also need to find if i can buy the turn signal harness seperate... you cant from the dealer
BANNED
that goes into the main harness at the other end. there are no lights on dash and there is nothing around where that wire can reach to go to. the only thing that would be there would be the resenator chamber
OP, what color is that connector (grey or black?) and how many cavities does it have? (I'm assuming the connector is female. Or is it a male connector?)
And this is the driver's side, correct?
you are going to have to follow the wire .. take a picture of what you find and maybe we can help more ... it could be some random aftermarket wire that a previous owner installed and never took out.
AZ Track Whore
following it back would be time consuming, painful, and kinda foolish... Why doesn't the OP try turning on the fog light switch (and other switches as well) and seeing if the connector has power. The clip holding it to the frame looks OEM but I can't say the connector/plug at the end does...
OP, as near as I can tell, it's likely an aftermarket wire/s. Your left front impact sensor is missing. According to the ETM, it should be mounted in the two holes marked by the red rectangle.
![](http://i263.photobucket.com/albums/ii154/jmillerl/8538757855_90ff09704c_h_zps45df4e01.jpg)
The wires to the impact sensor are Red and Black/Yellow...
Time to buy your own ETM. I'm done.
Acura604
20
08-05-2017 12:55 AM
SUPRMN84
10-07-2015 09:46 PM
