What changed each year 04-08?
05 Acura TL: a-spec
Hey guys.
I am planning on buying a 3g TL sometime in 2011. I am looking for any buying advise or recommendations you may have.
The main question I have right now is what changed each year from 04-08? I know the type s didn't come until 07, I just need to know about the major upgrades to the base tl each year.
If there happens to be a thread already created, please link me, I couldn't find one with search.
Thanks,
Chris
Thanks,
Chris
Wikipedia works?
http://en.wikipedia.org/wiki/Acura_T..._.28UA6-UA7.29
Those are the main things.
There are obviously little things that's not on Wikipedia such as in 2005, the steering wheel got a new emblem, etc.
Those things you won't actually need to know until you get a TL lol
Oh and btw, get a Type-S if you can find one =)
07-08 base has the fog lights, updated grill, cleaner head lights, led tail lights, new bumper, softer suspension, turn signal lights on the side view mirrors and a little updating in the interior, not much though.
Originally Posted by csmeance
honey, I'm home....
Ways to tell TL's Apart:
A 2004-2006 TL with a 6 speed manual will have huge brake capilers in the front that are black.
A 2004-2006 TL with 5 Speed Automatic has silver small brake capilers all around.
A 2005-2006 TL have an extra line of stitching on the inside
A 2005-2006 TL have the seatbelt anchored to the seat and not the floor
A 2005-2006 TL has a A symbol that is part plastic chrome, the 04 has a full plastic one.
A 2004-2006 TL has solid RED tail-lights
A 2004-2006 TL with Quartz and Ebony interior have Carbon Fiber trim
A 2004-2006 TL with Parchment or Camel interior have ORANGE WOOD trim
A 2004-2006 TL has a 4 spoke steering wheel
A 2004-2006 TL says HONDA ON WINDOWS AND EXTERIOR PARTS
A 2004-2006 TL has FULL AMBER reflectors in the headlights
A 2004-2006 TL has RED rear side markers
A 2004-2006 TL has satin exterior
A 2006 TL has a rectangle indent in the rims to have the TPMS sensor
A 2007-2008 TL has euro blinkers on the side-mirrors
A 2007-2008 TL has Fog lights at the bottom of the bumper with DRL's where the fogs were on the 2004-2006 TL
A 2007-2008 TL has a honeycomb cutout on the rear bumper between the muffler
tips
A 2007-2008 TL has larger grills on the front
A 2007-2008 TL has clear lenses Tail-lights with red parts within
A 2007-2008 TL has a 3 spoke steering wheel
A 2007-2008 TL has ACURA ON THE WINDOWS AND EXTERIOR PARTS
A 2007-2008 TL BASE has fake black wood interior trim
A 2007-2008 TL BASE has a clear middle section of the tail-light
A 2007-2008 TL Base has satin trim on the exterior
A 2007-2008 TL-S has a fake Carbon Fiber interior trim
A 2007-2008 TL-S has half clear, half Amber front reflectors
A 2007-2008 TL-S had grey rear side markers
A 2007-2008 TL-S has Chrome Trim instead of Satin Trim
A 2007-2008 TL-S had Huge Black Capilers in the front, both on AUTO AND MANUAL
A 2007-2008 TL-S has metal racing pedals
A 2007-2008 TL has a 10 spoke 17 inch rim while the 2004-2006 has a 5 spoke star rim
A 2007-2008 TL-S has 17 inch GUNMETAL rims.
A 2007-2008 TL-S has black rear capilers
A 2007-2008 TL-S has gunmetal in the tail-lights
A 2007-2008 TL-S has quad exhaust
A 2007-2008 TL-S has vertical stitching on the door-panels
A 2007-2008 TL-S has TYPE-S embossed into the headrests
Yes, I typed these all up.
the smaller things:
2004-2006 TL ALL, the underside of the headrest, and rear arm-rest side (near the door) is vinyl
2007-2008 TL ALL, the underside of the headrest is felt, along with the rear arm rest
2004-2006 TL NAV uses 3.xx version, XM RADIO ONLY
2007-2008 TL NAV uses 4.xx version, XM NAV TRAFFIC, MP3/WMA, AUX, Dobly Prologic 2 added
2007-2008 TL-S ANC added
2004-2006 TL ALL - gauges are black with blue semi-ring, red needles and white, MID in right, PRNDML in left cluster
2007-2008 TL BASE - Gauges have brushed background, blue rings around, white numbers, red needle, MID in center, PRNDML in right cluster
2007-2008 TL-S - Gauges have brushed background, RED rings around, white numbers, red needle, MID in center, PRNDML in right cluster
2004-2006 TL NAV- HFL, Navi buttons in bottom left corner of steering wheel
2007-2008 TL NAV- HFL, NAVI, MID buttons directly on bottom of steering wheel face
2004-2006 TL NON-NAV - radio display and temperature display together in 1 unit, NO COMPASS, Manual Clock adjustment, Blue backlight added either in 2005 or 2006
2007-2008 TL NON-NAV - radio display and temperature display appear to be 2 units, Compass, Manual Clock, white text, no backlight
2004-2006 5AT TL ALL black leather shifter standard
2007-2008 5AT TL BAse, black leather shift knob
2007-2008 5AT TL-S Black Leather with carbon fiber center shift-knob
2004-2006 TL Standard suspension firm, yet soft
2007-2008 TL BASE- Suspension softer than 2004-2006
2007-2008 TL-S - Suspension firmer than 2004-2006, but less then 2004-2008 ASPEC
2004-2006 TL 3.2 ALL engine cover simple plastic with manifold uncovered
2007-2008 TL 3.2 BASE engine cover plastic covering entire manifold with A symbol
2007-2008 TL-S 3.5 Engine cover plastic covering entire manifold with A symbol, 3.5 In red on cover
2004-2006 TL Battery cover clips on
2007-2008 TL ALL battery cover has different attachment system with knob
2004-2006 TL Air box rectangular
2007-2008 TL Air box With cut on one side
2004-2006 TL, Headliner and pillars are grey
2007-2008 TL BASE - Headliner and pillars grey
2007-2008 TL-S- Headliner is ebony along with pillars
2007-2008 TL (ALL) has switchblade keys
2007-2008 BASE TL has regular brakes
2007-2008 TL-S has Brembo Brakes (big black ones with acura on them)
Plus a bunch of other stuff that I can't think of right now..
tips
the smaller things:
you're welcome
If you get one with around 100,000 miles, make sure the plugs, timing belt, water pump, tensioner, serp belt, have been changed (a.k.a. the 105k service). Otherwise take $1200 (or more) off the price. If the seller doesn't go for it, walk away...
Any headliner is better than what you have. Go buy it. How the Hell is someone able to not control his/her cig's to the point of burning a headliner ill never understand. Smoking is gross as it is but making the car look/smell as gross as a smokers habit is beyond me...
how it happened, why it happened and how bad of a habit smoking is shouldn't be discussed here.
Why wouldn't it fit? 04-08 tl are structurally the same car so its not like u are asking if the 09 tl or rl liner would fit. Remember Type S is a trim level and not a different car all together. I hope you maintain control of your cigs better this time around.
For the OP, an updated navi would be nice and I feel the rims look nicer on the 07-08's.
They should fit but it'd look odd since the TL-S headliner is black vs. the grey headliner in all other TL's or tan colored ones. IMO, rather than buy a new one, why not take off the old one and wrap it in Alcantara! It'd look really nice and save you some money as well, plus no worries about fitment!
haha no it was NOT. 03 vs 04/05/06/07/08 the wheelbase changed. haha Dude read more about your car please. The 07/08 only got upgrades but its the same car. Call Acura and see what they tell you in parts. Schematics will give you all info.
True. Wheelbase is exactly the same all years. Track can change but that's a rim/tire issue, not a frame/body issue. Length changes can something as simple as a bumper cover change between a base/S/aspec but the structure of the car is exactly the same.
I am also thinking about doing the wrapping of the now burned headliner but I am scared that I might not be able to pull it off and then being stuck without the headliner with my interior all in pieces. So if I could change it up with a type-s black one, and then take my time on the wrapping, that would be perfect.
now it all depends on the price of the used type-s headliner because a shop that does interior work here locally quoted me 900$ for a re-wrap of the headliner
mada51589
05-03-2022 08:54 PM
acura_dipset_tl
01-01-2016 03:02 PM
IIDXholic
10-08-2015 07:53 AM
